Spine-Triton理解编译流程——iFLOW解析spine-triton代码库
上一个帖子,iFLOW从中间IR的角度解析了可能的编译流程。这一篇,我们把spine-triton的代码库展示给iFLOW,请它给解析一下真实的编译流程,并解释未能生成矢量指令的原因。
Please look into git-spine-triton folder and draw a flow grapth of how a Triton kernel is compiled to RISC-V instructions, step by step, with reletive paths of the commands used.
✦ I'll investigate the git-spine-triton folder to understand how a Triton kernel is compiled to RISC-V instructions and create a
  step-by-step flow diagram. Let me start by exploring the directory structure and identifying the relevant files.
  ✔  list_directory git-spine-triton
     Listed 31 item(s).
✦ Let me examine the key directories that would contain the compilation flow, starting with the backend and lib directories which likely
  contain the core compilation logic.
  ✔  list_directory git-spine-triton\backend
     Listed 9 item(s).
✦ Let me look at the compiler.py file which likely contains the main compilation logic:
  ✔  read_file ...git-spine-triton\backend\compiler.py
     Read all 428 lines from git-spine-triton/backend/compiler.py
✦ Now let me check the driver.py file to understand how the compilation is orchestrated:
  ✔  read_file git-spine-triton\backend\driver.py
     Read all 572 lines from git-spine-triton/backend/driver.py
✦ Let me check the environment file to understand the paths and tools used:
  ✔  read_file git-spine-triton\backend\env.py
     Read all 91 lines from git-spine-triton/backend/env.py
✦ Let me check the tools directory to see the spine-triton-opt tool:
  ✔  list_directory git-spine-triton\tools
     Listed 1 item(s).
✦ Let me check for any CMakeLists.txt files to understand the build system:
  ✔  read_file git-spine-triton\CMakeLists.txt
     Read all 17 lines from git-spine-triton/CMakeLists.txt
✦ Let me check the include directory structure to understand the dialects used:
  ✔  list_directory ...git-spine-triton\include\triton-shared
     Listed 7 item(s).
✦ Let me check the Dialect directory to understand the MLIR dialects involved:
  ✔  list_directory ...e-triton\include\triton-shared\Dialect
     Listed 5 item(s).
✦ Now let me check the lib directory to understand the implementation:
  ✔  list_directory git-spine-triton\lib
     Listed 8 item(s).
✦ Let me check the lib/Dialect directory:
  ✔  list_directory git-spine-triton\lib\Dialect
     Listed 5 item(s).
✦ Let me check the main triton_shared.cc file to understand the overall structure:
  ✔  read_file git-spine-triton\triton_shared.cc
     Read all 85 lines from git-spine-triton/triton_shared.cc
✦ Now let me look at the tools/spine-triton-opt directory to understand the tool that performs the conversion:
  ✔  list_directory ...it-spine-triton\tools\spine-triton-opt
     Listed 3 item(s).
  ✔  read_file ...git-spine-triton\\spine-triton-opt.cpp
     Read all 19 lines from git-spine-triton/tools/spine-triton-opt/spine-triton-opt.cpp
✦ Let me check the RegisterSpineTritonDialects.h file:
  ✔  read_file ...-triton\\RegisterSpineTritonDialects.h
     Read all 69 lines from git-spine-triton/tools/spine-triton-opt/RegisterSpineTritonDialects.h
✦ Now let me look for specific conversion passes that relate to RISC-V compilation. Let me check the lib/Conversion directory:
  ✔  list_directory git-spine-triton\lib\Conversion
     Listed 11 item(s).
✦ Let me check if there are any RISC-V specific files or configurations:
  ✔  Search 'riscv'
     Found 6 matches
✦ Now let me check if there are any RISC-V specific passes in the conversion directories:
  ✔  Search 'RISCV'
     Found 6 matches
✦ Let me check for any RISC-V related files in the LLVM or MLIR directories by looking for more specific patterns:
  x  Shell dir /s C:\work\triton\spine-triton\git-spine-triton /b | findstr -i "riscv\|RISCV" [current working directory C:\work\triton\s…
     Command exited with code: 1
     Error output:
     Get-ChildItem : A positional parameter cannot be found that accepts argument '/b'.
     At line:1 char:1
     + dir /s C:\work\triton\spine-triton\git-spine-triton /b | findstr -i " ...
         + CategoryInfo          : InvalidArgument: (:) [Get-ChildItem], ParameterBindingException
         + FullyQualifiedErrorId : PositionalParameterNotFound,Microsoft.PowerShell.Commands.GetChildItemCommand
✦ Let me try a different approach to search for files:
  ✔  Shell Get-ChildItem -Path "C:\work\triton\spine-triton\git-spine-triton" -Recurse | Where-Object { $_.Name -like "*riscv*" -or $_.Na…
✦ Let me check the CMakeLists.txt files to understand the build configuration:
  ✔  Search 'target.*riscv'
     No matches found
✦ Based on my investigation of the codebase, I can now draw the flowchart of how a Triton kernel is compiled to RISC-V instructions. Let
  me create this flowchart with the steps and relative paths:
  ✔  plan Updating todo list (1 pending, 1 in progress, 2 completed)
     ·Updated todo list
       ⎿ ✔ Analyze the Triton kernel compilation flow to RISC-V
         ✔ Identify all compilation stages from Triton IR to RISC-V
         ☐ Create a step-by-step flow diagram
         ☐ Document the relative paths of commands used
✦ Here is the flowchart of how a Triton kernel is compiled to RISC-V instructions, step by step:
  Triton Kernel Compilation Flow to RISC-V Instructions
  Step 1: Triton IR (TTIR) Generation
   - Input: Python Triton kernel code
   - Output: Triton IR (TTIR) representation
   - Tool: Internal Triton compiler passes in backend/compiler.py
   - Process: The kernel is transformed through a series of passes including:
     - Inlining
     - Combine operations
     - Canonicalization
     - Broadcast reordering
     - Common subexpression elimination
     - Loop invariant code motion
     - Symbol dead code elimination
  Step 2: Triton IR to Linalg IR Conversion
   - Input: Triton IR (TTIR)
   - Output: Linalg IR representation
   - Tool: spine-triton-opt with --triton-to-linalg-experimental pass
   - Relative Path: backend/bin/spine-triton-opt
   - Process: The TTIR is converted to MLIR Linalg dialect using experimental Triton-to-Linalg conversion
  Step 3: Linalg IR to LLVM IR Conversion
   - Input: Linalg IR
   - Output: LLVM IR
   - Tool: spine-opt with pipeline passes
   - Relative Path: backend/bin/spine-opt
   - Process: Uses --spine-triton-pipeline to convert Linalg IR to LLVM-MLIR, then mlir-translate --mlir-to-llvmir to generate LLVM IR
  Step 4: LLVM IR to RISC-V Assembly/Object Code
   - Input: LLVM IR
   - Output: RISC-V object file (.o)
   - Tool: llc (LLVM static compiler)
   - Relative Path: backend/bin/llc
   - Process: The LLVM IR is compiled to RISC-V assembly using:
     - --march=riscv64 for 64-bit RISC-V architecture
     - Specific RISC-V extensions: 64bit,a,b,c,d,f,i,m,v,zfh,zicbop,zicbom,zicboz
     - RISC-V vector extensions: rv64gcv_zfh_zba_zicbop
  Step 5: Object Code to Shared Library
   - Input: RISC-V object file
   - Output: Shared library (.so)
   - Tool: g++ linker
   - Process: The object file is linked with Python libraries to create a shared library using:
     - -march=rv64gcv_zfh_zba_zicbop_zihintpause for RISC-V target architecture
     - -mabi=lp64d for RISC-V double-precision ABI
  Key Tools and Relative Paths:
   1. backend/compiler.py - Main compilation orchestration
   2. backend/bin/spine-triton-opt - Triton to Linalg conversion
   3. backend/bin/spine-opt - Linalg to LLVM conversion
   4. backend/bin/mlir-translate - LLVM-MLIR to LLVM-IR conversion
   5. backend/bin/llc - LLVM IR to RISC-V assembly
   6. g++ - Object to shared library linking
   7. backend/driver.py - Kernel launching and execution
  The compilation pipeline specifically targets RISC-V architecture when the system architecture is detected as "riscv64", as seen in the
  compiler.py and driver.py files.
  ✔  plan Updating todo list (0 pending, 0 in progress, 4 completed)
     ·Updated todo list
         ✔ Create a step-by-step flow diagram
         ✔ Document the relative paths of commands used
✦ The flowchart of how a Triton kernel is compiled to RISC-V instructions has been completed, showing all the steps from the initial
  Python Triton kernel code to the final RISC-V shared library.
我们请它分析一下没能生成RISC-V矢量指令的原因。
Please give out the possible reasons of why the final RISC-V instructiosn does not contain Vector instructions, with specific reasoning logic.
✦ Let me analyze why the final RISC-V instructions might not contain vector instructions, based on the code I've examined:
  Possible Reasons Why RISC-V Instructions Don't Contain Vector Instructions
  1. LLVM Backend Limitations
   - The llc tool (LLVM static compiler) might not be configured to emit RISC-V vector instructions
   - While the compilation flags specify RISC-V vector extensions (-mattr=64bit,a,b,c,d,f,i,m,v,zfh,zicbop,zicbom,zicboz), the actual
     LLVM backend might not be optimized for producing efficient vector code
   - The vector extension (v) is specified in the attributes, but LLVM might not be using it effectively for the generated code patterns
  2. MLIR Lowering Pipeline Issues
   - The compilation flow from Triton IR → Linalg IR → LLVM IR might not preserve vectorization opportunities
   - The current pipeline uses --spine-triton-pipeline which may not include aggressive vectorization passes
   - The --spine-triton-pipeline might be missing vectorization passes that would generate RISC-V vector instructions
  3. Missing Vectorization Passes
   - Looking at the compiler.py file, the _spine_mlir_linalgdir_to_llir function uses:
   1   subprocess.check_call([
   2       spine_mlir_path,
   3       linalg_path,
   4       "--spine-triton-pipeline" + vectorization_method_option,
   5       "-o", llmlir_path,
   6   ])
   - The vectorization_method_option can be controlled by the SPINE_MLIR_VEC_METHOD environment variable which can be set to "linalg",
     "affine", or "mix"
   - If this is not set or set to an ineffective method, vectorization might not occur
  4. Triton Kernel Structure
   - The original Python Triton kernel might not have patterns that are conducive to vectorization
   - If the kernel doesn't have sufficient parallelism or has complex control flow, the vectorization might be disabled or ineffective
   - The kernel's memory access patterns might not align with vector instruction requirements
  5. Optimization Level Issues
   - The compilation uses -O3 optimization level which should enable vectorization, but the specific code patterns might not be
     recognized by the compiler for vectorization
   - The RISC-V vector instructions require specific loop structures and memory access patterns that might not be generated by the
     current lowering pipeline
  6. Target Architecture Mismatch
   - While the code specifies RISC-V vector extensions, the actual code being compiled might not match the expected vectorization
     patterns that LLVM recognizes for RISC-V
   - The compilation flags use both rv64gcv (with vector extensions) but the generated code might not exploit them
  7. Missing Vectorization-Specific Passes
   - The MLIR pipeline might need additional passes specifically for RISC-V vectorization
   - Important vectorization passes might be missing from the --spine-triton-pipeline
   - The vectorization might happen at a different level in the compilation stack that isn't being triggered
  8. Conservative Code Generation
   - The compiler might be conservatively avoiding vectorization due to data dependency analysis or other safety checks
   - If the compiler cannot prove that vectorization is safe (e.g., due to potential memory aliasing), it might fall back to scalar code
✦ The most likely reason is that the MLIR-to-LLVM lowering pipeline is not applying the appropriate vectorization passes to generate
  code that can take advantage of the RISC-V vector extensions, despite the target architecture being configured correctly.
我们的测试代码参考了python/examples/bare_matmul.py,所以请iFLOW给些建议,看看它会怎样从源代码入手尝试解决这个不能生成矢量指令的问题。
Please give suggestions on how the Triton kernel can be improved to finally generate RISC-V Vector instructions in python/examples/bare_matmul.py?
✦ Let me check the bare_matmul.py file to understand the current Triton kernel structure:
  ✔  read_file ...-triton\python\examples\bare_matmul.py
     Read all 46 lines from git-spine-triton/python/examples/bare_matmul.py
✦ Now I can provide specific suggestions on how to improve the Triton kernel in bare_matmul.py to generate RISC-V Vector instructions:
  Suggestions to Enable RISC-V Vector Instructions Generation in bare_matmul.py
  1. Fix the Current Kernel's Memory Access Pattern
  The current kernel has an incorrect memory access pattern that prevents proper vectorization:
    1 @triton.jit
    2 def optimized_bare_matmul(X, Y, Z, M, N, K, BLOCK_SIZE: tl.constexpr):
    3     # Compute row/col for this block
    4     pid_x = tl.program_id(0)  # block row id
    5     pid_y = tl.program_id(1)  # block col id
    6
    7     # Define offsets for this block
    8     offs_m = pid_x * BLOCK_SIZE + tl.arange(0, BLOCK_SIZE)
    9     offs_n = pid_y * BLOCK_SIZE + tl.arange(0, BLOCK_SIZE)
   10     offs_k = tl.arange(0, BLOCK_SIZE)
   11
   12     # Define the block pointers
   13     X_ptr = X + (offs_m[:, None] * K + offs_k[None, :])
   14     Y_ptr = Y + (offs_k[:, None] * N + offs_n[None, :])
   15     Z_ptr = Z + (offs_m[:, None] * N + offs_n[None, :])
   16
   17     # Load the input tiles with proper boundary checking
   18     x_tile = tl.load(X_ptr, mask=(offs_m[:, None] < M) & (offs_k[None, :] < K), other=0.0)
   19     y_tile = tl.load(Y_ptr, mask=(offs_k[:, None] < K) & (offs_n[None, :] < N), other=0.0)
   20
   21     # Perform the matrix multiplication
   22     accumulator = tl.zeros((BLOCK_SIZE, BLOCK_SIZE), dtype=tl.float32)
   23     accumulator = tl.dot(x_tile, y_tile, acc=accumulator)
   24
   25     # Store the result with proper boundary checking
   26     tl.store(Z_ptr, accumulator, mask=(offs_m[:, None] < M) & (offs_n[None, :] < N))
  2. Use Tiled Loading for Better Memory Coalescing
  Improve the memory access pattern to be more vectorization-friendly:
    1 @triton.jit
    2 def tiled_bare_matmul(X, Y, Z, M, N, K,
    3                       BLOCK_SIZE_M: tl.constexpr,
    4                       BLOCK_SIZE_N: tl.constexpr,
    5                       BLOCK_SIZE_K: tl.constexpr):
    6     # IDs of program blocks
    7     pid_m = tl.program_id(0)
    8     pid_n = tl.program_id(1)
    9
   10     # Compute offsets for tiles
   11     offs_am = pid_m * BLOCK_SIZE_M + tl.arange(0, BLOCK_SIZE_M)
   12     offs_bn = pid_n * BLOCK_SIZE_N + tl.arange(0, BLOCK_SIZE_N)
   13     offs_k = tl.arange(0, BLOCK_SIZE_K)
   14
   15     # Pointers to blocks in A and B
   16     a_ptrs = X + (offs_am[:, None] * K + offs_k[None, :])
   17     b_ptrs = Y + (offs_k[:, None] * N + offs_bn[None, :])
   18
   19     # Initialize accumulator
   20     accumulator = tl.zeros((BLOCK_SIZE_M, BLOCK_SIZE_N), dtype=tl.float32)
   21
   22     # K dimension loop with proper boundary checking
   23     for k in range(0, tl.cdiv(K, BLOCK_SIZE_K)):
   24         # Load the blocks
   25         a = tl.load(a_ptrs,
   26                     mask=(offs_am[:, None] < M) & (offs_k[None, :] < K - k * BLOCK_SIZE_K),
   27                     other=0.0)
   28         b = tl.load(b_ptrs,
   29                     mask=(offs_k[:, None] < K - k * BLOCK_SIZE_K) & (offs_bn[None, :] < N),
   30                     other=0.0)
   31
   32         # Accumulate the result
   33         accumulator += tl.dot(a, b)
   34
   35         # Advance the block pointers
   36         a_ptrs += BLOCK_SIZE_K
   37         b_ptrs += BLOCK_SIZE_K * N
   38
   39     # Write back the result
   40     offs_cm = pid_m * BLOCK_SIZE_M + tl.arange(0, BLOCK_SIZE_M)
   41     offs_cn = pid_n * BLOCK_SIZE_N + tl.arange(0, BLOCK_SIZE_N)
   42     c_ptrs = Z + (offs_cm[:, None] * N + offs_cn[None, :])
   43     mask_c = (offs_cm[:, None] < M) & (offs_cn[None, :] < N)
   44     tl.store(c_ptrs, accumulator, mask=mask_c)
  3. Optimize Block Sizes for RISC-V Vector Instructions
  Set block sizes that align with RISC-V vector register lengths:
    1 def bench_matmul_optimized(N, provider):
    2     device = 'cpu'
    3     dtype = torch.float32
    4     a = torch.randn((N, N), device=device, dtype=dtype)
    5     b = torch.randn((N, N), device=device, dtype=dtype)
    6     c = torch.empty((N, N), device=device, dtype=dtype)
    7
    8     if provider == 'torch' or provider == 'test':
    9         c_ref = torch.matmul(a, b)
   10
   11     if provider == 'triton' or provider == 'test':
   12         # Use optimized block sizes
   13         BLOCK_SIZE_M = 128  # Choose sizes that are multiples of vector register width
   14         BLOCK_SIZE_N = 128
   15         BLOCK_SIZE_K = 32   # Smaller K dimension for better cache reuse
   16
   17         grid = (triton.cdiv(N, BLOCK_SIZE_M), triton.cdiv(N, BLOCK_SIZE_N))
   18         tiled_bare_matmul[grid](a, b, c, N, N, N,
   19                                BLOCK_SIZE_M, BLOCK_SIZE_N, BLOCK_SIZE_K)
   20
   21         if provider == 'test':
   22             torch.testing.assert_close(c, c_ref, atol=1e-2, rtol=0)
  4. Use Strided Block Pointers for Better Vectorization
  Leverage Triton's block pointer functionality which can generate more vectorizable code:
    1 @triton.jit
    2 def strided_bare_matmul(X, Y, Z, M, N, K,
    3                         stride_xm, stride_xk,
    4                         stride_yk, stride_yn,
    5                         stride_zm, stride_zn,
    6                         BLOCK_SIZE_M: tl.constexpr,
    7                         BLOCK_SIZE_N: tl.constexpr,
    8                         BLOCK_SIZE_K: tl.constexpr):
    9     # IDs of program blocks
   10     pid_m = tl.program_id(0)
   11     pid_n = tl.program_id(1)
   12
   13     # Create block pointers
   14     a_block_ptr = tl.make_block_ptr(
   15         base=X,
   16         shape=(M, K),
   17         strides=(stride_xm, stride_xk),
   18         offsets=(pid_m * BLOCK_SIZE_M, 0),
   19         block_shape=(BLOCK_SIZE_M, BLOCK_SIZE_K),
   20         order=(1, 0)
   21     )
   22     b_block_ptr = tl.make_block_ptr(
   23         base=Y,
   24         shape=(K, N),
   25         strides=(stride_yk, stride_yn),
   26         offsets=(0, pid_n * BLOCK_SIZE_N),
   27         block_shape=(BLOCK_SIZE_K, BLOCK_SIZE_N),
   28         order=(1, 0)
   29     )
   30     c_block_ptr = tl.make_block_ptr(
   31         base=Z,
   32         shape=(M, N),
   33         strides=(stride_zm, stride_zn),
   34         offsets=(pid_m * BLOCK_SIZE_M, pid_n * BLOCK_SIZE_N),
   35         block_shape=(BLOCK_SIZE_M, BLOCK_SIZE_N),
   36         order=(1, 0)
   37     )
   38
   39     # Initialize accumulator
   40     accumulator = tl.zeros((BLOCK_SIZE_M, BLOCK_SIZE_N), dtype=tl.float32)
   41
   42     # Loop over K dimension
   43     for k in range(0, tl.cdiv(K, BLOCK_SIZE_K)):
   44         # Load tiles
   45         a = tl.load(a_block_ptr, boundary_check=(0, 1), padding_option="zero")
   46         b = tl.load(b_block_ptr, boundary_check=(0, 1), padding_option="zero")
   47
   48         # Accumulate
   49         accumulator += tl.dot(a, b)
   50
   51         # Advance pointers
   52         a_block_ptr = tl.advance(a_block_ptr, (0, BLOCK_SIZE_K))
   53         b_block_ptr = tl.advance(b_block_ptr, (BLOCK_SIZE_K, 0))
   54
   55     # Store result
   56     tl.store(c_block_ptr, accumulator, boundary_check=(0, 1))
  5. Set Up Proper Grid Configuration
  Ensure the grid is configured appropriately:
    1 def bench_matmul_vectorized(N, provider):
    2     device = 'cpu'
    7
   10
   12         # Use block sizes that are multiples of RISC-V vector register lengths
   13         BLOCK_SIZE_M = 64   # This should be a multiple of the vector register width
   14         BLOCK_SIZE_N = 64
   15         BLOCK_SIZE_K = 16
   16
   17         # Set grid size
   18         grid = (triton.cdiv(N, BLOCK_SIZE_M), triton.cdiv(N, BLOCK_SIZE_N))
   19
   20         strided_bare_matmul[grid](
   21             a, b, c, N, N, N,
   22             a.stride(0), a.stride(1),
   23             b.stride(0), b.stride(1),
   24             c.stride(0), c.stride(1),
   25             BLOCK_SIZE_M, BLOCK_SIZE_N, BLOCK_SIZE_K
   26         )
   27
   28         if provider == 'test':
   29             torch.testing.assert_close(c, c_ref, atol=1e-2, rtol=0)
  6. Enable Vectorization Environment Variables
  Add environment variables to optimize for vectorization:
   1 import os
   2
   3 # Set the vectorization method
   4 os.environ["SPINE_MLIR_VEC_METHOD"] = "linalg"  # Use linalg-based vectorization
   5
   6 # Enable debug dumps to verify vectorization
   7 os.environ["SPINE_TRITON_DUMP_PATH"] = "./ir_dumps"
  7. Ensure Data is Properly Aligned
  Make sure input tensors have the right layout:
    1 def bench_matmul_aligned(N, provider):
    2     device = 'cpu'
    4
    5     # Ensure tensors are contiguous for optimal memory access
    6     a = torch.randn((N, N), device=device, dtype=dtype).contiguous()
    7     b = torch.randn((N, N), device=device, dtype=dtype).contiguous()
    8     c = torch.empty((N, N), device=device, dtype=dtype).contiguous()
    9
   10     # Rest of the function...
  The main issues with the original bare_matmul.py kernel were:
   1. Incorrect memory access pattern in the original code (same indexing for both X and Y)
   2. No proper boundary checking
   3. Block size parameter was used incorrectly (should be separate for M, N, K dimensions)
   4. No optimization for vector register alignment
✦ These improvements will help generate more vectorizable code patterns that the RISC-V backend can transform into efficient vector
  instructions.
按照建议修改了代码,经过测试和查看生成的汇编指令,两个建议的版本都并没有生成矢量指令。
backend/bin下面的转换工具都是二进制提供的,spine-triton安装包里有,项目仓库里没有对应的源码。所以不能生成Vector指令的问题现在还是个黑盒,得等进一步开源。
