Installation:
sudo apt install llama.cpp-tools-spacemit
/etc/apt/sources.list.d/bianbu.sources
/etc/apt/sources.list.d/ubuntu.sources
需要把这两个文件里面的https改成http;
执行这个命令cat <>/etc/hosts 10.0.72.104 archive.bianbu.xyz EOF
Download Model
You can also download the model locally from the cloud experience and upload it via scp for faster transfer.
wget https://huggingface.co/unsloth/Qwen3-30B-A3B-Instruct-2507-
GGUF/resolve/b144a30c8aa1b7fb943ea2971970052557e855ca/Qwen3-30B-A3B-Instruct-
2507-Q4_0.gguf
Usage
First Method:llama-server
Run the command to start the llama.cpp service:
llama-server -m Qwen3-30B-A3B-Instruct-2507-Q4_0.gguf -t 8 --host 127.0.0.1 --
port 8080 --ctx-size 15360 --n-gpu-layers 0 --batch-size 512 --metrics --nommap
Open the llama server in your browser by navigating to http://localhost:8080 and use llama.cpp directly in the browser.
Second Method:Local API Request
After starting the llama-server above, instead of accessing via the browser, use the command below to send a request:
curl http://localhost:8080/v1/chat/completions \
-H "Content-Type: application/json" \
-d '{
"model": "qwen3",
"messages": [{"role": "user", "content": "介绍⼀下⾃⼰"}]
Third Method:llama-cli
No need to start the llama-server mentioned above. Run the command directly:
llama-cli -m Qwen3-30B-A3B-Instruct-2507-Q4_0.gguf -t 8 --no-mmap -c 15360
