Spine-Triton Attention Implementation
When you write standard Triton, you think in terms of threads and warps operating on GPU SIMD units. When you write spine-triton, you’re mental model ought to be a little different: a tiled matrix engine with explicit format control. It is actually better this way, you’d be surprised how often the compiler sucks at handling this. It also lets you handle batch tricks and unsupported datatypes, like GEMV. This post walks through what I learned building attention for the K1, focusing on why the SMT primitives exist and how they map to the underlying linalg.mmt4d operations.
My opinion after all of this… It was an interesting middle ground between high level and low level. The primary thing the programmer needs out of low level is this granular control. I think as spine-triton matures it will be an excellent DSL for its platform. I cover some usage ambiguities in this post. I think good answers to these ambiguities will provide important pieces of what else is needed from low level while keeping the code easier to write, namely controlling the flow of data through computation; while also keeping the really painful parts out of the code, like core scheduling.
The Matrix Engine Mental Model
Most ML accelerators (Tensor Cores, AMX, TPU) share a common pattern: they want data in a specific tiled format, they compute on fixed-size micro-tiles, and they accumulate into special registers. The K1 Matrix Engine follows this model, but spine-triton makes the tiling explicit rather than hidden in intrinsics. My opinion is this is a great decision for a DSL for niche hardware. We get the higher level abstraction of Triton, with more control than Triton normally offers. With out this someone would come along and port another DSL for the hardware and fragment the ecosystem later. For the immediate future of RISCV, spine-triton is a brilliant decision.
The compilation flow looks like:
Triton kernel with smt.*
TTIR with xsmt.* ops
    ↓  [XSMTToLinalg]
linalg.mmt4d + linalg.pack/unpack
LLVM IR → RISC-V
Smt primitives exist to generate linalg.mmt4d - the 4D tiled matmul that maps directly to hardware instructions.
What mmt4d Actually Means
When you see linalg.mmt4d, you’re looking at a matmul that operates on 4D tensors:
C[M/m, N/n, m, n] += A[M/m, K/k, m, k] @ B[K/k, N/n, k, n]
Where:
  • Capital letters (M, N, K) are the logical dimensions
  • Lowercase letters (m, n, k) are the micro-tile sizes (hardware-specific)
    • These must cleanly divide with no remainder.
This format lets the hardware:
  1. Stream in micro-tiles sequentially (better memory patterns, potentially less fragmentation compared to standard triton)
  2. Keep micro-tiles in special registers (avoid shuffle overhead)
  3. Compute with fixed-size matrix units (simpler datapath)
Based on my research for the K1, the micro-tiles are typically 8×8 or 8×16. This matches the matrix engine’s native compute granularity.
Building Block 1: The Descriptor Load
Let’s start with the most fundamental operation: getting data into the matrix engine:
a_packed = smt.descriptor_load(
    block_ptr,
    (offset_m, offset_k),    # Where in the block
    (SUB_BLK_M, BLOCK_K),    # Logical shape: e.g., [32, 64]
    (MICRO_M, MICRO_K)       # Micro shape: e.g., [8, 8]
This takes a 2D tile [32, 64] and repacks it to [4, 8, 8, 8]:
  • Outer dimensions: [32/8, 64/8] = [4, 8] (number of micro-tiles)
  • Inner dimensions: [8, 8] (micro-tile size)
Why does this matter? The hardware matrix unit expects data in this packed format. If you tried to use standard tl.load, you’d get flat 2D data, and the compiler would have to insert pack operations - or worse, fall back to scalar loops. I can’t instrument this to be certain, but it is very likely the case.
From reading semantic.py in the source:
result_shape = [
    shape[0] // micro_size[0],
    shape[1] // micro_size[1],
    micro_size[0],
    micro_size[1]
The descriptor load does this packing explicitly, giving the compiler maximum flexibility for DMA scheduling and prefetch. Enabling potentially lower memory fragmentation compared to standard triton.
Building Block 2: The Accumulator View
For matrix multiply, you need: C = A @ B + C. The + C part requires special handling because C is also in packed format:
acc = tl.zeros((BLOCK_M, BLOCK_N), dtype=tl.float32)  # Start flat
# Create a view with micro-tiling structure
acc_view = smt.view(
    acc,
    (offset_m, offset_n),     # Which part of C
    (SUB_BLK_M, SUB_BLK_N),   # View shape
    (MICRO_M, MICRO_N)        # Micro sizes
# Now acc_view has the 4D structure for mmt4d
acc_view = smt.dot(a_packed, b_packed, acc_view)
The smt.view creates a packed 4D view of a portion of the accumulator. AT the IR level, it lowers to a combination of slice extraction and linalg.pack operations, preparing the data for the tiled matmul.
Building Block 3: Putting It Together for Q @ K^T
Here’s where it gets interesting. For attention, we compute Q @ K^T:
  • Q is [M, D] (sequence length × head dimension)
  • K is [N, D] (same)
  • K^T is conceptually [D, N]
We want to compute this in tiles, loading K once and reusing it across Q sub-blocks:
# Load K^T as packed 4D tensor (ONCE, outside the loop)
k_block_ptr = tl.make_block_ptr(
    base=k_ptr,
    shape=[D, N],                    # Logical shape of K^T
    strides=[stride_kd, stride_kn],  # Swapped for transpose
    offsets=[0, pid_n * BLOCK_N],
    block_shape=[BLOCK_D, BLOCK_N],
    order=[1, 0],
k_packed = smt.descriptor_load(
    k_block_ptr, (0, 0),
    (BLOCK_D, BLOCK_N),
    (MICRO_K, MICRO_N)
# Initialize accumulator for output tile [BLOCK_M, BLOCK_N]
# Iterate over M in sub-blocks (parallelizable)
for s in smt.parallel(0, num_sub_blocks):
    # Load Q sub-block
    q_packed = smt.descriptor_load(
        q_block_ptr,
        (s * SUB_BLK_M, 0),
        (SUB_BLK_M, BLOCK_D),
        (MICRO_M, MICRO_K)
    # Create view into accumulator for this sub-block
        acc,
        (s * SUB_BLK_M, 0),
        (SUB_BLK_M, BLOCK_N),
        (MICRO_M, MICRO_N)
    # Accumulate: C[sub] += Q[sub] @ K^T
    acc_view = smt.dot(q_packed, k_packed, acc_view)
The pattern: load once, reuse, accumulate. The K matrix stays in packed format across iterations.
Note: The “load once, reuse” pattern works for the QK kernel because K is loaded once per output tile and reused across Q sub-blocks. However, the fused attention kernel below must reload K for each KV block. Why? The online softmax needs to iterate over the entire sequence dimension, so we can’t cache K across blocks. This is the tradeoff that comes with FlashAttention-style streaming.
Why smt.parallel?
The smt.parallel(0, n) wrapper is a hint to the compiler that these iterations are independent. Unlike standard range(), it signals:
  • No loop-carried dependencies
  • Can vectorize or parallelize across cores
  • Each iteration computes on a disjoint memory region
Whether the backend actually parallelizes depends on hardware resources and the Linalg → LLVM lowering strategy.
The Format Transition Problem: Why Full Attention is Hard
Let’s think about complete attention: softmax(Q @ K^T) @ V
  1. Q @ K^T: Perfect for SMT - pure matmul, both operands in packed format
  2. Softmax: Element-wise (max, exp, sum, div) - runs on vector units, not matrix engine
  3. P @ V: Could use SMT, but there’s a catch…
After softmax, the probability matrix P lives in flat 2D registers. To use smt.dot for P @ V, you’d need to:
# 1. Allocate shared memory (4D layout)
#smt.alloc returns a 4D tensor: [BLOCK_M/m, BLOCK_N/n, m, n]
p_scratch = smt.alloc((BLOCK_M, BLOCK_N), (MICRO_M, MICRO_N), dtype=tl.float32)
# 2. Reshape 2D probs into 4D packed format
num_m_tiles = BLOCK_M // MICRO_M
num_n_tiles = BLOCK_N // MICRO_N
for m_tile in range(num_m_tiles):
    for n_tile in range(num_n_tiles):
        # Extrat microtiles
        m_start = m_tile * MICRO_M
        n_start = n_tile * MICRO_N
        micro_tile = p[m_start:m_start+MICRO_M, n_start:n_start+MICRO_N]
        # Assign to 4D
        p_scratch[m_tile, n_tile] = micro_tile
# 3. Reload as packed tensor
# p_packed = smt.descriptor_load(p_scratch_ptr, ...) pointer conversion?
p_packed = p_scratch #if not pointer, then just copy and let the compiler solve it
# 4. Now can use smt.dot
acc = smt.dot(p_packed, v_packed, acc)
There are no examples of this pattern in the codebase. The smt.alloc primitive exists, but the store/reload dance isn’t documented. Here is how to reason through this if you have hardware to compile on.
  • Does smt.alloc return a pointer you can tl.store to?
  • Or does it return a special tensor type?
  • Can smt.descriptor_load operate on local allocations?
  • What’s the latency penalty for this round-trip?
Without hardware to test, I can’t answer these. So the implementation makes a pragmatic choice.
Implementation Strategy: Two Kernels
Kernel 1: Pure SMT for Q @ K^T
@triton.jit
def smt_qk_kernel(...):
    """Clean demonstration of SMT primitives for matrix multiply."""
    # ... setup block pointers ...
    k_packed = smt.descriptor_load(k_block_ptr, ...)
    for s in smt.parallel(0, sub_num):
        q_packed = smt.descriptor_load(q_block_ptr, ...)
        acc_view = smt.view(acc, ...)
    out = acc * sm_scale
    tl.store(out_ptr, out)
This is the reference implementation - it shows the correct SMT pattern without complications. Both operands packed, proper accumulator views, clean loop structure.
Kernel 2: Full Attention with Hybrid Path
For the fused kernel, the online softmax requirement changes the memory access pattern. We must iterate over all KV positions to compute the global softmax statistics, which means K is streamed per KV block rather than loaded once and reused.
@triton.jit
def smt_attention_fused_kernel(...):
    """Full attention with online softmax, using SMT where clear."""
    # Outer loop over K/V blocks (FlashAttention style)
    for block_idx in range(num_kv_blocks):
        # PHASE 1: Q @ K^T via SMT
        # (K is loaded per KV block; not cached across blocks)
        qk = tl.zeros((BLOCK_M, BLOCK_N), dtype=tl.float32)
            qk_view = smt.view(qk, ...)
            qk_view = smt.dot(q_packed, k_packed, qk_view)
        qk = qk * sm_scale
        # PHASE 2: Online softmax (standard Triton)
        # Update running max
        m_ij = tl.max(qk, axis=1)
        m_new = tl.maximum(m_i, m_ij)
        # Compute exponentials with correction factor
        alpha = tl.exp(m_i - m_new)
        p_ij = tl.exp(qk - m_new[:, None])
        # Update running sum
        l_new = alpha * l_i + tl.sum(p_ij, axis=1)
        # PHASE 3: P @ V
        # Using tl.dot instead of SMT because the
        # p_ij to packed format transition is unclear
        # (see smt.alloc discussion earlier for potential SMT approach)
        v = tl.load(v_block_ptr)
        acc = acc * alpha[:, None]  # Apply correction factor
        acc += tl.dot(p_ij.to(v.dtype), v)
        # Update statistics
        l_i = l_new
        m_i = m_new
    # Final output
    out = acc / l_i[:, None]
What the IR Should Look Like
Even without hardware to compile, we can reason about the TTIR → Linalg transformation:
xsmt.descriptor_load → linalg.pack
xsmt.dot → linalg.mmt4d
xsmt.view → memrfe.subview + linalg.pack
Standard tl.dot → linalg.matmul (unpacked)
The compiler inserts linalg.unpack operations where needed to convert between packed 4D and flat 2D representations. With SPINE_TRITON_DUMP_PATH set, you’d see:
// After XSMTToLinalg pass
%packed_a = linalg.pack %a inner_dims_pos = [0, 1]
                             inner_tiles = [8, 8] ...
%packed_b = linalg.pack %b ...
%result = linalg.mmt4d ins(%packed_a, %packed_b : ...)
                       outs(%packed_c : ...)
%unpacked = linalg.unpack %result ...
The beauty of this design: the tiling metadata ([8, 8]) is explicit in the IR, so backend code generators can make informed decisions about register allocation and instruction selection.
Open Questions for SpacemiT
If you’re reading this and want to help the community:
  1. Scratchpad pattern: Can you show an example of:
    scratch = smt.alloc(...)
    # store something to scratch
    # reload via smt.descriptor_load
  2. Descriptor lifetime: Is k_packed consumed by smt.dot, or can it be reused across multiple dot calls?
  3. Mixed precision: How do you control accumulator precision? FP16 inputs with FP32 accumulation?
  4. Micro-tile constraints: What are the valid (MICRO_M, MICRO_N, MICRO_K) combinations for different K1 variants? Generally CuTe provides this as a table in the repo, I did not find an equivalent.
  5. Performance model: What’s the theoretical peak GFLOPS for linalg.mmt4d on K1? This helps validate whether kernels are hardware-bound or software-bound.
Repo: https://github.com/bigwolfeman/Spine-Triton
Thank you for this great article!
I tried to run the code but there was one strange error:
SMT Attention Demo
Input: Q=torch.Size([128, 64]), K=torch.Size([128, 64]), V=torch.Size([128, 64])
1. Testing smt_qk_kernel (Q @ K^T)...
Error: There are multiple ExtractSliceOp users
/home/bibo/work/git-spine-triton/python/examples/attention_smt.py:119:12: error: failed to legalize operation 'xsmt.view' that was explicitly marked illegal
            (MICRO_M, MICRO_N),
/home/bibo/work/git-spine-triton/python/examples/attention_smt.py:119:12: note: see current operation: %109 = "xsmt.view"(%14, %80, %6) <{micro_size = array<i32: 8, 16>, shape = array<i32: 32, 64>}> : (tensor<64x64xf32>, i64, i64) -> tensor<4x4x8x16xf32>
            (MICRO_M, MICRO_N),
/home/bibo/work/git-spine-triton/python/examples/attention_smt.py:119:12: note: see current operation: %54 = "xsmt.view"(%14, %52, %6) <{micro_size = array<i32: 8, 16>, shape = array<i32: 32, 64>}> : (tensor<64x64xf32>, i64, i64) -> tensor<4x4x8x16xf32>
Traceback (most recent call last):
  File "/home/bibo/work/git-spine-triton/python/examples/attention_smt.py", line 531, in <module>
    scores = run_smt_qk(Q, K)
  File "/home/bibo/work/git-spine-triton/python/examples/attention_smt.py", line 391, in run_smt_qk
    smt_qk_kernel[grid](
        Q, K, out,
    ...<13 lines>...
        MICRO_K=MICRO_K,      # spine-triton specific SMT parameter
  File "/home/bibo/work/venv/spine-triton/lib/python3.13/site-packages/triton/runtime/jit.py", line 390, in <lambda>
    return lambda *args, **kwargs: self.run(grid=grid, warmup=False, *args, **kwargs)
  File "/home/bibo/work/venv/spine-triton/lib/python3.13/site-packages/triton/runtime/jit.py", line 594, in run
    kernel = self.compile(src, target=target, options=options.__dict__)
  File "/home/bibo/work/venv/spine-triton/lib/python3.13/site-packages/triton/compiler/compiler.py", line 359, in compile
    next_module = compile_ir(module, metadata)
  File "/home/bibo/work/venv/spine-triton/lib/python3.13/site-packages/triton/backends/spine_triton/compiler.py", line 303, in <lambda>
    _ttir_to_linalgdir(src, metadata)
  File "/home/bibo/work/venv/spine-triton/lib/python3.13/site-packages/triton/backends/spine_triton/compiler.py", line 32, in _ttir_to_linalgdir
    subprocess.check_call(
    ...<5 lines>...
  File "/usr/lib/python3.13/subprocess.py", line 419, in check_call
    raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['/home/bibo/work/venv/spine-triton/lib/python3.13/site-packages/triton/backends/spine_triton/bin/spine-triton-opt', '/tmp/tmp_pksdj46/tt.mlir', '--triton-to-linalg-experimental', '-o', '/tmp/tmp_pksdj46/linalg.mlir']' returned non-zero exit status 1.
I modified one line and the error is gone:
    # Step 5: Scale and store output
    out = acc # * sm_scale
    out = out.to(out_ptr.dtype.element_ty)
I can fix this error by not using sm_scale.
    # out = acc * sm_scale
    out = acc * (1.0 / (BLOCK_D ** 0.5))
It can also be fixed this way:
    # sm_scale,  # 1/sqrt(d) scaling factor
    sm_scale: tl.constexpr,  # 1/sqrt(d) scaling factor
I am honestly shocked only 1 change was needed to run. Thank you so much for running this. I will update the repo soon. This makes much more sense than what I originally wrote. My implementation feels like an anti-pattern now.
Please see my thread Spine-Triton编译器bug——常数乘法双重错误. There are dual bugs in the Triton to Triton-IR pass. Your original code should be just fine and remain the same. However, I will go ahead to learn the core online softmax kernel.
A further compilation error is revealed in this thread Spine-Triton编译器bug——tt.mlir to linalg.mlir. This time it is in the pass from Triton IR to Linalg IR.
Honestly, I am glad I never got a chance to compile the code now. I would have been chasing this for days.
pip install PyYAML sympy torch opencv-python pybind11 --index-url https://git.spacemit.com/api/v4/projects/33/packages/pypi/simple
Looking in indexes: https://git.spacemit.com/api/v4/projects/33/packages/pypi/simple
ERROR: Could not find a version that satisfies the requirement PyYAML (from versions: none)
ERROR: No matching distribution found for PyYAML 是不是工具链变化了,我怎么连一开始环境都不对
特化一下torch的install版本试试,pip install PyYAML sympy torch==2.8.0+spacemit.0 opencv-python pybind11 --index-url https://git.spacemit.com/api/v4/projects/33/packages/pypi/simple
还是没有成功,有没有什么具体的下载清单吗,我不用他们带的这个包,直接一个个build install 有可能吗,我在海外不知道是不是还有这个原因
最近升级服务器,也有可能是网络问题,用公版torch、pyyaml、pybind11也可以
谢谢,我回去试试
