orangepi rv2启动xv6时,开启分页硬件出现异常
楼主尝试在orangepi rv2上运行xv6,通过在u-boot加载bin文件到指定内核指定地址,然后再运行go命令,使其在指定地址上开始运行。当程序运行到写入分页硬件satp寄存器时,CPU似乎停止了工作,不再有任何输出。通过gdb调试发现此时内核出现异常,并跳转到kernelvec函数,然而它只会一直停留在第一条指令,不会继续往下运行。
作为对比,我在QEMU上运行一样的程序时,并没有发现相同的错误。
我怀疑可能对于K1芯片来说,写入分页硬件需要进行额外的操作。如果有朋友遇到类似的问题,希望不吝赐教。不胜感激!
GDB
(gdb) target remote localhost:3333
Remote debugging using localhost:3333
wait_debugger () at kernel/entry.S:30
30                          bnez t0, wait_debugger
(gdb) info threads
  Id   Target Id                                                  Frame
* 1    Thread 1 "k1.cpu.0" (Name: k1.cpu.0, state: debug-request) wait_debugger ()
(gdb) break vm.c:106
Breakpoint 1 at 0x8000d5c: file kernel/vm.c, line 106.
(gdb) set $t0=0
(gdb) continue
Continuing.
Disabling abstract command writes to CSRs.
Breakpoint 1, kvminithart () at kernel/vm.c:106
106       sbi_console_puts("kvminithart: make satp\n");
(gdb) info registers mstatus stvec
mstatus        0x8000000a00006680       SD:1 VM:00 MXR:0 PUM:0 MPRV:0 XS:0 FS:3 MPP:0 HPP:3 SPP:0 MPIE:1 HPIE:0 SPIE:0 UPIE:0 MIE:0 HIE:0 SIE:0 UIE:0
stvec          0x80052c0        134238912
(gdb) next
[k1.cpu.0] Found 8 triggers
108       w_satp(satp_value);
(gdb) si
109       sbi_console_puts("kvminithart: write satp\n");
(gdb) si
kernelvec () at kernel/kernelvec.S:18
18              addi sp, sp, -256
mstatus        0x8000000a00006780       SD:1 VM:00 MXR:0 PUM:0 MPRV:0 XS:0 FS:3 MPP:0 HPP:3 SPP:1 MPIE:1 HPIE:0 SPIE:0 UPIE:0 MIE:0 HIE:0 SIE:0 UIE:0
(gdb) info registers scause
scause         0xc      12
(gdb) si
(gdb) si
(gdb) si
(gdb) info registers all
zero           0x0      0
ra             0x8000d68        0x8000d68 <kvminithart+54>
sp             0x8009af0        0x8009af0 <stack0+8112>
gp             0x7de9cd50       0x7de9cd50
tp             0x1      0x1
t0             0x2000   8192
t1             0x9000001        150994945
t2             0x80028c0        134228160
fp             0x8009b10        0x8009b10 <stack0+8144>
s1             0x800000000000ffff       -9223372036854710273
a0             0x0      0
a1             0x0      0
a2             0x0      0
a3             0x0      0
a4             0x6      6
a5             0x8000000000000000       -9223372036854775808
a6             0x0      0
a7             0x1      1
s2             0x7dfbbf20       2113650464
s3             0x2      2
s4             0x7dfbbf20       2113650464
s5             0x7efe420c       2130592268
s6             0x0      0
s7             0x0      0
s8             0x0      0
s9             0x7dfbb0d0       2113646800
s10            0x0      0
s11            0x0      0
t3             0x0      0
t4             0x0      0
t5             0x8004af6        134236918
t6             0x7de938d0       2112436432
pc             0x80052c0        0x80052c0 <kernelvec>
QEMU
OpenSBI v1.5.1
   ____                    _____ ____ _____
  / __ \                  / ____|  _ \_   _|
 | |  | |_ __   ___ _ __ | (___ | |_) || |
 | |  | | '_ \ / _ \ '_ \ \___ \|  _ < | |
 | |__| | |_) |  __/ | | |____) | |_) || |_
  \____/| .__/ \___|_| |_|_____/|____/_____|
        |_|
Platform Name             : riscv-virtio,qemu
Platform Features         : medeleg
Platform HART Count       : 3
Platform IPI Device       : aclint-mswi
Platform Timer Device     : aclint-mtimer @ 10000000Hz
Platform Console Device   : uart8250
Platform HSM Device       : ---
Platform PMU Device       : ---
Platform Reboot Device    : syscon-reboot
Platform Shutdown Device  : syscon-poweroff
Platform Suspend Device   : ---
Platform CPPC Device      : ---
Firmware Base             : 0x80000000
Firmware Size             : 347 KB
Firmware RW Offset        : 0x40000
Firmware RW Size          : 91 KB
Firmware Heap Offset      : 0x4d000
Firmware Heap Size        : 39 KB (total), 2 KB (reserved), 11 KB (used), 25 KB (free)
Firmware Scratch Size     : 4096 B (total), 416 B (used), 3680 B (free)
Runtime SBI Version       : 2.0
Domain0 Name              : root
Domain0 Boot HART         : 0
Domain0 HARTs             : 0*,1*,2*
Domain0 Region00          : 0x0000000000100000-0x0000000000100fff M: (I,R,W) S/U: (R,W)
Domain0 Region01          : 0x0000000010000000-0x0000000010000fff M: (I,R,W) S/U: (R,W)
Domain0 Region02          : 0x0000000002000000-0x000000000200ffff M: (I,R,W) S/U: ()
Domain0 Region03          : 0x0000000080040000-0x000000008005ffff M: (R,W) S/U: ()
Domain0 Region04          : 0x0000000080000000-0x000000008003ffff M: (R,X) S/U: ()
Domain0 Region05          : 0x000000000c400000-0x000000000c5fffff M: (I,R,W) S/U: (R,W)
Domain0 Region06          : 0x000000000c000000-0x000000000c3fffff M: (I,R,W) S/U: (R,W)
Domain0 Region07          : 0x0000000000000000-0xffffffffffffffff M: () S/U: (R,W,X)
Domain0 Next Address      : 0x0000000080200000
Domain0 Next Arg1         : 0x0000000087e00000
Domain0 Next Mode         : S-mode
Domain0 SysReset          : yes
Domain0 SysSuspend        : yes
Boot HART ID              : 0
Boot HART Domain          : root
Boot HART Priv Version    : v1.12
Boot HART Base ISA        : rv64imafdch
Boot HART ISA Extensions  : sstc,zicntr,zihpm,zicboz,zicbom,sdtrig,svadu
Boot HART PMP Count       : 16
Boot HART PMP Granularity : 2 bits
Boot HART PMP Address Bits: 54
Boot HART MHPM Info       : 16 (0x0007fff8)
Boot HART Debug Triggers  : 2 triggers
Boot HART MIDELEG         : 0x0000000000001666
Boot HART MEDELEG         : 0x0000000000f0b509
hart0
xv6 kernel is booting
freerange
kinit done
kvminit done
kvminithart done
看看这个: VisionFive v1下移植xv6 - 昉·星光 2(CN) - RVspace Forum
感谢,目前已经可以正常分页。
是你做的吗大佬:移植xv6到SpacemiT K1 - #2,来自 1dentity - xv6-riscv - RISC-V 开发者社区
大佬,这是我做的,发布在另外一个论坛了 :face_with_peeking_eye:
