第一次使用K1,在东山那里买了MUSE PI PRO,回来下载固件bianbu-25.04-desktop-k1-v3.0.1-release-20250815185656,使用 刷机工具烧录卡启动,启动后Log如下,无法进入系统。帮忙看是什么问题?
[ 4.228094] printk: console [ttyS0] enabled
[ 4.236282] printk: bootconsole [sbi0] disabled
[ 4.246906] d4017100.uart: ttyS2 at MMIO 0xd4017100 (irq = 78, base_baud = 3600000) is a UART3
[ 4.260063] spacemit_hwcrng f0703800.crng: registered RNG driver
[ 4.261132] random: crng init done
[ 4.286266] Reserved memory: detected bootloader logo memory at 0x000000007f000000, size 16 MB
[ 4.296998] Freeing framebuffer memory: 16380K
[ 4.302019] [drm] spacemit_dsi_probe()
[ 4.306992] [drm] rpi_touchscreen_probe()
[ 4.511300] rpi_touchscreen 5-0045: Atmel I2C read issue: -6, please check LCD connection
[ 4.521552] PVR_K: 1: Read BVNC 36.29.52.182 from HW device registers
[ 4.528263] PVR_K: 1: RGX Device registered BVNC 36.29.52.182 with 1 core in the system
[ 4.537191] [drm] Initialized pvr 24.2.6603887 20170530 for cac00000.imggpu on minor 0
[ 4.551758] loop: module loaded
[ 4.557200] Rounding down aligned max_sectors from 4294967295 to 4294967288
[ 4.564477] db_root: cannot open: /etc/target
[ 4.570797] k1x-qspi d420c000.spi: config mfp for cs:[0]
[ 4.576340] k1x-qspi d420c000.spi: AHB buf size: 512
[ 4.581833] k1x-qspi d420c000.spi: RX buffer overflow
[ 4.609060] spi-nor spi4.0: w25q64dw (8192 Kbytes)
[ 4.622180] k1x-qspi d420c000.spi: Runtime PM usage count underflow!
[ 4.629571] tun: Universal TUN/TAP device driver, 1.6
[ 4.634936] CAN device driver interface
[ 4.780082] PPP generic driver version 2.4.2
[ 4.784741] usbcore: registered new interface driver cdc_ether
[ 4.790673] usbcore: registered new interface driver cdc_subset
[ 4.796684] usbcore: registered new interface driver zaurus
[ 4.802629] mv-usb2-phy c0940000.usbphy: phy-k1x-ci-usb2: will select HS parallel data path
[ 4.811234] mv-usb2-phy c09c0000.usbphy1: phy-k1x-ci-usb2: will select HS parallel data path
[ 4.819845] mv-usb2-phy c0a30000.usb2phy: phy-k1x-ci-usb2: will select HS parallel data path
[ 4.829456] spacemit-k1x-combphy c0b10000.phy: USB3 PHY init.
[ 4.835291] spacemit-k1x-combphy c0b10000.phy: USB3 PHY init lfps thres 3
[ 4.843811] mv-ehci mv-ehci1: Spacemit EHCI
[ 4.848180] mv-ehci mv-ehci1: new USB bus registered, assigned bus number 1
[ 4.855448] mv-ehci mv-ehci1: irq 85, io mem 0xc0980100
[ 4.873916] mv-ehci mv-ehci1: USB 2.0 started, EHCI 1.00
[ 4.880065] hub 1-0:1.0: USB hub found
[ 4.883899] hub 1-0:1.0: 1 port detected
[ 4.888913] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 4.894580] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 4.902545] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe6d hci version 0x110 quirks 0x0000008000000090
[ 4.912352] xhci-hcd xhci-hcd.0.auto: irq 84, io mem 0xc0a00000
[ 4.918483] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 4.924049] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3
[ 4.931808] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 4.938932] hub 2-0:1.0: USB hub found
[ 4.942766] hub 2-0:1.0: 1 port detected
[ 4.947046] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[ 4.955663] hub 3-0:1.0: USB hub found
[ 4.959490] hub 3-0:1.0: 1 port detected
[ 4.963980] usbcore: registered new interface driver uas
[ 4.969414] usbcore: registered new interface driver usb-storage
[ 4.975765] spacemit-usb3-hub soc:usb3hub@0: v1.0.2
[ 5.185905] spacemit-usb3-hub soc:usb3hub@0: onboard usb hub driver probed, hub configured
[ 5.194729] mv-udc c0900100.udc: mv_udc_probe enter ...Driver: v2
[ 5.201343] mv-udc mv-udc: use 32bit DMA mask
[ 5.205882] mv-udc mv-udc: dqh size = 0x800 udc->ep_dqh_dma = 0x7f048000
[ 5.213184] mv-udc mv-udc: successful probe UDC device without clock gating.
[ 5.220601] f_tcm: UAS support multiple cmds
[ 5.225148] Gt9xx driver installing..
[ 5.228990] raspits-ft5426: raspits_ft5426_probe: address = 0x38
[ 5.235284] input: fts_ts as /devices/platform/soc/d4013800.i2c/i2c-5/5-0038/input/input0
[ 5.243823] <I>CTS-SPIDrv Chipone touch driver init, version: v3.7.0-sz
[ 5.250590] <I>CTS-SPIDrv - Register spi driver
[ 5.250695] raspits-ft5426: fts_i2c_read: i2c read issue, please check touchscreen connection, -6
[ 5.255324] <I>CTS-SPIDrv - Register touch driver successfully
[ 5.264240] raspits-ft5426: raspits_ft5426_work: checking touch ic, countdown: 8
[ 5.278088] spacemit-pmic-pwrkey spacemit-pwrkey@spm8821: DMA mask not set
[ 5.337083] input: spacemit pwrkey as /devices/platform/soc/d401d800.i2c/i2c-8/8-0041/spacemit-pwrkey@spm8821/input/input1
[ 5.349161] spacemit-pmic-rtc spacemit-rtc@spm8821: DMA mask not set
[ 5.382476] spacemit-pmic-rtc spacemit-rtc@spm8821: registered as rtc0
[ 5.394344] spacemit-pmic-rtc spacemit-rtc@spm8821: setting system clock to 2000-01-01T00:00:00 UTC (946684800)
[ 5.405830] i2c_dev: i2c /dev entries driver
[ 5.413040] MVX dev: Linlon v5276 identified. cores=2, nlsid=4, id=0, fuse=00000000, hw_id=00005276, hw_rev=00000050
[ 5.424658] d420a000.csiphy begin to probe
[ 5.428882] d420a000.csiphy probed
[ 5.428979] d4206000.csiphy begin to probe
[ 5.436593] d4206000.csiphy probed
[ 5.437510] d420a000.ccic probed in k1x_ccic_probe
[ 5.441718] d420a800.ccic probed in k1x_ccic_probe
[ 5.447186] d4206000.ccic probed in k1x_ccic_probe
[ 5.458425] acquire ccic0 ctrl dev succeed
[ 5.467458] acquire ccic1 ctrl dev succeed
[ 5.471598] acquire ccic2 ctrl dev succeed
[ 5.481127] vcam_inf: svivi_probe 1115: svivi probe ok.
[ 5.486566] usbcore: registered new interface driver uvcvideo
[ 5.495784] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[ 5.508156] device-mapper: uevent: version 1.0.3
[ 5.513040] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[ 5.522035] device-mapper: multipath round-robin: version 1.2.0 loaded
[ 5.528649] device-mapper: multipath queue-length: version 0.2.0 loaded
[ 5.535340] device-mapper: multipath service-time: version 0.3.0 loaded
[ 5.542036] device-mapper: multipath historical-service-time: version 0.1.1 loaded
[ 5.549766] Bluetooth: HCI UART driver ver 2.3
[ 5.554263] Bluetooth: HCI UART protocol H4 registered
[ 5.559493] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 5.568608] sdhci: Secure Digital Host Controller Interface driver
[ 5.574892] sdhci: Copyright(c) Pierre Ossman
[ 5.579276] sdhci-pltfm: SDHCI platform and OF driver helper
[ 5.585546] sdhci-spacemit d4280000.sdh: Got CD GPIO
[ 5.629239] mmc0: SDHCI controller on d4280000.sdh [d4280000.sdh] using ADMA
[ 5.661922] mmc1: SDHCI controller on d4280800.sdh [d4280800.sdh] using ADMA
[ 5.669059] sdio: save sdio_host <- 000000001da4b3a4
[ 5.706749] mmc0: set tx_delaycode: 159
[ 5.713175] mmc0: pass window [17 73)
[ 5.722131] mmc0: pass window [79 225)
[ 5.726060] mmc0: pass window [226 227)
[ 5.730119] mmc0: pass window [229 230)
[ 5.734905] mmc0: pass window [239 255)
[ 5.738860] mmc0: tuning done, use the firstly delay_code:151
[ 5.745562] mmc0: new ultra high speed SDR104 SDHC card at address 1388
[ 5.752858] mmcblk0: mmc0:1388 MSSD0 29.2 GiB
[ 5.761147] mmcblk0: p1 p2 p3 p4 p5
[ 5.861921] usb 2-1: new high-speed USB device number 2 using xhci-hcd
[ 6.058679] hub 2-1:1.0: USB hub found
[ 6.062672] hub 2-1:1.0: 5 ports detected
[ 6.153501] usb 3-1: new SuperSpeed USB device number 2 using xhci-hcd
[ 6.227708] mmc2: new HS400 Enhanced strobe MMC card at address 0001
[ 6.234719] mmcblk2: mmc2:0001 A3A552 58.3 GiB
[ 6.244819] mmcblk2: p1 p2 p3 p4 p5 p6
[ 6.249744] mmcblk2boot0: mmc2:0001 A3A552 4.00 MiB
[ 6.255712] mmcblk2boot1: mmc2:0001 A3A552 4.00 MiB
[ 6.261602] mmcblk2rpmb: mmc2:0001 A3A552 16.0 MiB, chardev (239:0)
[ 6.268001] mmc2: SDHCI controller on d4281000.sdh [d4281000.sdh] using ADMA
[ 6.277459] hid: raw HID events driver (C) Jiri Kosina
[ 6.278111] raspits-ft5426: fts_i2c_read: i2c read issue, please check touchscreen connection, -6
[ 6.282962] usbcore: registered new interface driver usbhid
[ 6.291574] raspits-ft5426: raspits_ft5426_work: checking touch ic, countdown: 7
[ 6.298760] hub 3-1:1.0: USB hub found
[ 6.304640] usbhid: USB HID core driver
[ 6.306118] remoteproc remoteproc0: rcpu_rproc is available
[ 6.308588] hub 3-1:1.0: 4 ports detected
[ 6.313968] remoteproc remoteproc0: powering up rcpu_rproc
[ 6.331468] remoteproc remoteproc0: Booting fw image esos.elf, size 290248
[ 6.338786] rproc-virtio rproc-virtio.2.auto: Failed to set DMA mask 3fffffff. Trying to continue... (-EIO)
[ 6.354127] the firmare version id is:k1-x:22a8416f07c2
[ 6.359420] rproc-virtio rproc-virtio.2.auto: vdev 0 buffer already mapped
[ 6.465057] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 6.465457] virtio_rpmsg_bus virtio0: creating channel rcpu-pwr-management-service addr 0x400
[ 6.470647] rproc-virtio rproc-virtio.2.auto: registered virtio0 (type 7)
[ 6.479319] virtio_rpmsg_bus virtio0: creating channel i2c-service addr 0x401
[ 6.486045] remoteproc remoteproc0: remote processor rcpu_rproc is now up
[ 6.486385] k1x_rproc virtio0.rcpu-pwr-management-service.-1.1024: new channel: 0x400 -> 0x400!
[ 6.493371] i2c_k1x virtio0.i2c-service.-1.1025: new channel: 0x401 -> 0x401!
[ 6.500666] spacemit-pmic-adc spacemit-adc@spm8821: DMA mask not set
[ 6.510233] virtio_rpmsg_bus virtio0: creating channel rir-service addr 0x402
[ 6.529917] ir_spacemit virtio0.rir-service.-1.1026: new channel: 0x402 -> 0x402!
[ 6.531931] riscv-pmu-sbi: SBI PMU extension is available
[ 6.537739] virtio_rpmsg_bus virtio0: creating channel ruart-service0 addr 0x403
[ 6.542980] riscv-pmu-sbi: 16 firmware and 18 hardware counters
[ 6.550483] pxa_k1x virtio0.ruart-service0.-1.1027: new channel: 0x403 -> 0x403!
[ 6.564320] c0881000.r_uart0: ttyS10 at MMIO 0xc0881000 (irq = 42330, base_baud = 1536000) is a UART11
[ 6.565176] usbcore: registered new interface driver snd-usb-audio
[ 6.574339] virtio_rpmsg_bus virtio0: creating channel ruart-service1 addr 0x404
[ 6.587577] pxa_k1x virtio0.ruart-service1.-1.1028: new channel: 0x404 -> 0x404!
[ 6.587747] es8326 2-0019: Can not read property spk_ctl_gpio
[ 6.595322] virtio_rpmsg_bus virtio0: creating channel adma-service addr 0x405
[ 6.600855] es8326 2-0019: Can not read property hp-detect-gpio
[ 6.608211] adma_spacemit virtio0.adma-service.-1.1029: new channel: 0x405 -> 0x405!
[ 6.614099] es8326 2-0019: Can not read property mic-detect-gpio
[ 6.622399] Connection create success
[ 6.627968] es8326 2-0019: assuming static mclk
[ 6.629605] NET: Registered PF_INET6 protocol family
[ 6.668365] Segment Routing with IPv6
[ 6.672149] In-situ OAM (IOAM) with IPv6
[ 6.676184] NET: Registered PF_PACKET protocol family
[ 6.681294] can: controller area network core
[ 6.685744] NET: Registered PF_CAN protocol family
[ 6.690580] can: raw protocol
[ 6.693559] can: broadcast manager protocol
[ 6.697795] can: netlink gateway - max_hops=1
[ 6.702392] Bluetooth: RFCOMM TTY layer initialized
[ 6.707321] Bluetooth: RFCOMM socket layer initialized
[ 6.712527] Bluetooth: RFCOMM ver 1.11
[ 6.716314] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.721666] Bluetooth: BNEP filters: protocol multicast
[ 6.726929] Bluetooth: BNEP socket layer initialized
[ 6.731933] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.737895] Bluetooth: HIDP socket layer initialized
[ 6.743170] Key type dns_resolver registered
[ 6.757277] registered taskstats version 1
[ 6.761683] Loading compiled-in X.509 certificates
[ 6.774882] Key type .fscrypt registered
[ 6.778889] Key type fscrypt-provisioning registered
[ 6.784706] AppArmor: AppArmor sha1 policy hashing enabled
[ 6.790284] ima: No TPM chip found, activating TPM-bypass!
[ 6.795824] Loading compiled-in module X.509 certificates
[ 6.803852] Loaded X.509 cert 'Build time autogenerated kernel key: 8b54714d4ca3536db19a47c4f78b42e26445d735'
[ 6.813867] ima: Allocated hash algorithm: sha1
[ 6.818439] ima: No architecture policies found
[ 6.825955] usb 2-1.5: new high-speed USB device number 3 using xhci-hcd
[ 6.834005] suspend: SBI SUSP extension detected
[ 6.840075] [drm] spacemit_dpu_bind()
[ 6.844058] spacemit-dpu-drv soc:port@c0440000: assigned reserved memory node dpu_reserved@2ff40000
[ 6.853548] [drm] dpu plane init ok
[ 6.857153] spacemit-drm-drv c0440000.display-subsystem-hdmi: bound soc:port@c0440000 (ops dpu_component_ops)
[ 6.867568] spacemit-drm-drv c0440000.display-subsystem-hdmi: bound c0400500.hdmi (ops spacemit_hdmi_ops)
[ 6.877755] [drm] Initialized spacemit 1.0.0 20231115 for c0440000.display-subsystem-hdmi on minor 1
[ 6.886999] [drm] spacemit_hdmi_connector_detect() hdmi status disconnected
[ 6.894104] spacemit-drm-drv c0440000.display-subsystem-hdmi: [drm] Cannot find any crtc or sizes
[ 6.903161] [drm] spacemit_hdmi_connector_detect() hdmi status disconnected
[ 6.910216] spacemit-drm-drv c0440000.display-subsystem-hdmi: [drm] Cannot find any crtc or sizes
[ 6.911425] spacemit-socinfo soc:socinfo@0: Spacemit: CPU[M1-8571] REV[C] DRO[124] Detected
[ 6.929387] cam_sensor soc:cam_sensor@0: supply af_2v8 not found, using dummy regulator
[ 6.937692] cam_sensor soc:cam_sensor@0: supply avdd_2v8 not found, using dummy regulator
[ 6.946053] cam_sensor soc:cam_sensor@0: supply dovdd_1v8 not found, using dummy regulator
[ 6.954439] cam_sensor soc:cam_sensor@0: supply dvdd_1v2 not found, using dummy regulator
[ 6.962759] cam_inf:snr (camsnr_of_parse 1451): close soc mclk, guess sensor had mclk
[ 6.962759]
[ 6.972156] cam_inf:snr (camsnr_of_parse 1470): camsnr_of_parse: unable to parse sensor0 reset gpio
[ 6.981291] cam_inf:snr (cam_sensor_probe 1555): camera sensor0 probed
[ 6.988354] cam_sensor soc:cam_sensor@2: supply af_2v8 not found, using dummy regulator
[ 6.996558] cam_sensor soc:cam_sensor@2: supply avdd_2v8 not found, using dummy regulator
[ 7.004859] cam_sensor soc:cam_sensor@2: supply dovdd_1v8 not found, using dummy regulator
[ 7.013269] cam_sensor soc:cam_sensor@2: supply dvdd_1v2 not found, using dummy regulator
[ 7.021550] cam_inf:snr (camsnr_of_parse 1451): close soc mclk, guess sensor had mclk
[ 7.021550]
[ 7.030995] cam_inf:snr (camsnr_of_parse 1470): camsnr_of_parse: unable to parse sensor2 reset gpio
[ 7.040116] cam_inf:snr (cam_sensor_probe 1555): camera sensor2 probed
[ 7.047296] enter spacemit_snd_sspa_pdev_probe
[ 7.302096] raspits-ft5426: fts_i2c_read: i2c read issue, please check touchscreen connection, -6
[ 7.311075] raspits-ft5426: raspits_ft5426_work: checking touch ic, countdown: 6
[ 7.698981] input: snd-es8326 Headset Jack as /devices/platform/snd-card@1/sound/card1/input2
[ 7.708098] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.717544] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 7.723962] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 7.733815] clk: Not disabling unused clocks
[ 7.738221] ALSA device list:
[ 7.741188] #1: snd-es8326
[ 7.745132] Freeing unused kernel image (initmem) memory: 2304K
[ 7.753853] Checked W+X mappings: passed, no W+X pages found
[ 7.759612] Run /init as init process
[ 7.763300] with arguments:
[ 7.766292] /init
[ 7.768581] with environment:
[ 7.771755] HOME=/
[ 7.774139] TERM=linux
[ 8.006159] codec got the chain event: HEADSET_EVENT_DISCONNECTED
[ 8.326142] raspits-ft5426: fts_i2c_read: i2c read issue, please check touchscreen connection, -6
[ 8.335179] raspits-ft5426: raspits_ft5426_work: checking touch ic, countdown: 5
[ 8.370888] k1x_emac cac80000.ethernet end0: renamed from eth0
[ 9.350128] raspits-ft5426: fts_i2c_read: i2c read issue, please check touchscreen connection, -6
[ 9.359139] raspits-ft5426: raspits_ft5426_work: checking touch ic, countdown: 4
[ 10.374156] raspits-ft5426: fts_i2c_read: i2c read issue, please check touchscreen connection, -6
[ 10.383151] raspits-ft5426: raspits_ft5426_work: checking touch ic, countdown: 3
[ 11.398087] raspits-ft5426: fts_i2c_read: i2c read issue, please check touchscreen connection, -6
[ 11.407045] raspits-ft5426: raspits_ft5426_work: checking touch ic, countdown: 2
[ 12.422091] raspits-ft5426: fts_i2c_read: i2c read issue, please check touchscreen connection, -6
[ 12.431029] raspits-ft5426: raspits_ft5426_work: checking touch ic, countdown: 1
[ 13.445969] raspits-ft5426: raspits_ft5426_work: checking touch ic timeout, -6
BusyBox v1.37.0 (Ubuntu 1:1.37.0-4ubuntu1) built-in shell (ash)
Enter 'help' for a list of built-in commands.
(initramfs)
