I have written a simple python script that runs an inference on alexnet obtained from onnx model zoo. the aim of this script is to compare what kind of improvement does using the ‘SpaceMITExecutionProvider’ compared to the ‘CPUExecutionProvider’. The surprise came to me when the performance of SpaceMITExecutionProvider performs worse than the CPUExecutionProvider.
this is the script i have:
import argparse
import os
import numpy as np
import onnxruntime as ort
import spacemit_ortInitialize argument parser
parser = argparse.ArgumentParser(description=“Run ONNX model inference with terminal inputs.”)
parser.add_argument(“–model_name”, type=str, required=True, help=“Name of the ONNX model file (without path).”)
parser.add_argument(“–execution_provider”, type=str, choices=[“cpu”, “space”], required=True,
help=“Execution provider to use: ‘cpu’ or ‘space’.”)
parser.add_argument(“–batch_size”, type=int, default=1, help=“Batch size of the input tensor.”)
parser.add_argument(“–height”, type=int, default=224, help=“Height of the input tensor.”)
parser.add_argument(“–width”, type=int, default=224, help=“Width of the input tensor.”)
parser.add_argument(“–channels”, type=int, default=3, help=“Number of channels in the input tensor.”)
parser.add_argument(“–intra_op_threads”, type=int, default=2, help=“Number of intra-op threads.”)
parser.add_argument(“–inter_op_threads”, type=int, default=1, help=“Number of inter-op threads.”)
args = parser.parse_args()Model directory and full path
model_dir = “/home/kishki/bme688/modelzoo”
onnx_model_path = os.path.join(model_dir, args.model_name)Check if the model file exists
if not os.path.isfile(onnx_model_path):
raise FileNotFoundError(f"Model file ‘{args.model_name}’ not found in directory ‘{model_dir}’.")Set execution provider
if args.execution_provider == “cpu”:
EP = [“CPUExecutionProvider”]
elif args.execution_provider == “space”:
EP = [“SpaceMITExecutionProvider”]
else:
raise ValueError(“Invalid execution provider selected. Choose ‘cpu’ or ‘space’.”)Configure ONNX runtime session
sess_options = ort.SessionOptions()
sess_options.intra_op_num_threads = args.intra_op_threads
sess_options.inter_op_num_threads = args.inter_op_threads
#sess_options.log_severity_level = 0Create the inference session
session = ort.InferenceSession(onnx_model_path, sess_options, providers=EP)
Prepare input tensor
batch_size = args.batch_size
height = args.height
width = args.width
channels = args.channels
input_tensor = np.ones((batch_size, channels, height, width), dtype=np.float32)Perform inference
input_name = session.get_inputs()[0].name
output_names = [output.name for output in session.get_outputs()]
outputs = session.run(output_names, {input_name: input_tensor})
and i run it via a bash script as follows:
#!/bin/bash
Array of thread configurations
intra_op_threads=(1 2 4 6 8)
inter_op_threads=(1 2 4 6 8)
execution_providers=(‘cpu’ ‘space’)Output file
output_file=“stats_alexnet.txt”
Clear previous output file
$output_file
Loop through each execution provider and thread configuration
for ep in “${execution_providers[@]}”; do
for intra in “${intra_op_threads[@]}”; do
for inter in “${inter_op_threads[@]}”; do# Echo execution provider and thread settings echo "${ep^}ExecutionProvider - intra_op_threads=$intra, inter_op_threads=$inter" | tee -a $output_file # Run perf stat and append the results to the output file perf stat -e cycles,instructions,vector_inst python3 benchmark.py \ --model_name alexnet_Opset16.onnx \ --execution_provider $ep \ --intra_op_threads $intra \ --inter_op_threads $inter 2>> $output_file donedone
done
Can someone explain why this is the case? Is it a problem with my scripts? I am new to the platform and currently writing my master thesis about the topic of riscv.
kind regards!
