Although the website mentions somewhere that +5V low-voltage input is not currently supported, the core module schematic shows a power selection path that should allow +5V input when MODULE_ID is pulled low.
The carrier board was designed with reference to the schematic on the official website, and it boots normally with a 7.5V high-voltage input. However, when MODULE_ID is pulled down to GND through a 1kΩ resistor, with all other signals unchanged, the board fails to boot with a +5V input, and the core module draws less than 10mA. How can I get it to work with a +5V input?
The core module model is K3-CoM260_V03_20260312.
