What super-resolution models run well on the K3? It feels pretty slow
The board I have is a **SpacemiT K3 Com260 ** with 8 GB of RAM.
I used a DeepSeek Harness agent to build a real-time super-resolution app for a USB camera:
  • Qt 6.10 + C++ / OpenCV 4.10, with both qmake and CMake projects
  • 320×240 input → 4× upscaling, with three views in the UI: side-by-side comparison, split slider, and difference heatmap; supports 1:1 pixel scaling
  • Inference uses SpaceMIT EP in SpacemiT’s customized ONNX Runtime 1.24.2, running on the A100 NPU
  • Model comparison: anime version RealESRGAN x4plus anime 4B32F (1.4 MB INT8) and general-purpose x4plus (17.5 MB INT8)
  • Added real-time detail gain / sharpening / contrast / saturation controls to the UI, plus 18 command-line parameters and headless screenshots for validation
Current test results:
Model Input Time Peak memory
Anime INT8 320×240 166 ms/frame 1031 MB
General-purpose INT8 192×144 430 ms/frame 2406 MB
Is this pretty slow for the available processing power, or is it normal? Are there any ways to improve it? I don’t understand hardware or code; I only know how to use agents.
