After quantizing depth-anything 3 to int8, it works normally with the default CPU backend, but specifying the hardware backend causes a segmentation fault:
/lib/apport/coredump)
[info] onnxruntime 1.24.0+spacemit.a3
[info] available providers: ['SpaceMITExecutionProvider', 'CPUExecutionProvider' ]
[info] spacemit_ort loaded: True
[info] model: /home/lzdz/Depth-Anything-3-onnxinfer/models/da3_small.q.onnx (27 .1 MB)
[info] session loaded in 14.715s
[info] providers in use: ['SpaceMITExecutionProvider', 'CPUExecutionProvider']
[info] input 'images': model shape=[1, 2, 3, 280, 504] -> run shape=(1, 2, 3, 28 0, 504)
[info] output 'depth': model shape=[1, 2, 280, 504] type=tensor(float)
[info] output 'depth_conf': model shape=[1, 2, 280, 504] type=tensor(float)
[info] output 'extrinsics': model shape=[1, 2, 3, 4] type=tensor(float)
[info] output 'intrinsics': model shape=[1, 2, 3, 3] type=tensor(float)
[info] fake input: shape=(1, 2, 3, 280, 504) dtype=float32 min=-2.0000 max=2.000 0 mean=0.0002 nonfinite=0
段错误(核心已转储)
(myenv) lzdz@lzdz-spacemitk1xmusepiproboard:~/Depth-Anything-3-onnxinfer$ gdb -b atch \
-ex "bt 20" \
-ex "info sharedlibrary" \
/usr/bin/python3 \
/var/lib/apport/coredump/core._usr_bin_python3_12.1000.426568dc-8ba0-4501-9d2d -1014aec4ddfe.527082.8637948 \
2>&1 | tee /tmp/gdb.txt
[New LWP 527118]
[New LWP 527082]
[New LWP 527084]
[New LWP 527119]
[New LWP 527104]
[New LWP 527088]
[New LWP 527085]
[New LWP 527103]
[New LWP 527121]
[New LWP 527089]
[New LWP 527086]
[New LWP 527120]
[New LWP 527090]
[New LWP 527087]
[New LWP 527105]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/riscv64-linux-gnu/libthread_db.so.1".
Core was generated by `python test.py'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x0000003f6dd67e70 in onnxruntime::spacemit::OnnxTensorData::GetBufferRaw() () from /home/lzdz/spacemit-demo-main/spacemit_ort_2.0.5/spacemit_ort/libspacemi t_ep.so.2.0.5
[Current thread is 1 (Thread 0x3f66f83180 (LWP 527118))]
#1 0x0000003f6ddaed44 in onnxruntime::spacemit::SpineUnaryOperator::Compile(onn xruntime::spacemit::SpineGraphExecutor&) () from /home/lzdz/spacemit-demo-main/s pacemit_ort_2.0.5/spacemit_ort/libspacemit_ep.so.2.0.5
#2 0x0000003f6ddaf8fa in ?? () from /home/lzdz/spacemit-demo-main/spacemit_ort_ 2.0.5/spacemit_ort/libspacemit_ep.so.2.0.5
#3 0x0000003f6dd7f4d4 in onnxruntime::spacemit::SpineOperatorManager::CreateOpe rator(onnxruntime::spacemit::SpineGraphExecutor&, onnxruntime::spacemit::SpineNo de&) () from /home/lzdz/spacemit-demo-main/spacemit_ort_2.0.5/spacemit_ort/libsp acemit_ep.so.2.0.5
#4 0x0000003f6deae29a in onnxruntime::spacemit::SpineGraphExecutor::AddKernels( ) () from /home/lzdz/spacemit-demo-main/spacemit_ort_2.0.5/spacemit_ort/libspace mit_ep.so.2.0.5
#5 0x0000003f6dec5908 in ?? () from /home/lzdz/spacemit-demo-main/spacemit_ort_ 2.0.5/spacemit_ort/libspacemit_ep.so.2.0.5
#6 0x0000003f834d13fc in ?? () from /lib/riscv64-linux-gnu/libstdc++.so.6
#7 0x0000003f853ce19c in start_thread (arg=<optimized out>) at ./nptl/pthread_c reate.c:447
#8 0x0000003f854202ac in __thread_start_clone3 () at ../sysdeps/unix/sysv/linux /riscv/clone3.S:71
From To Syms Read Shared Object Library
0x0000003f85529540 0x0000003f85566c10 Yes /lib/riscv64-linux-gnu/libm. so.6
0x0000003f85504490 0x0000003f855123c2 Yes (*) /lib/riscv64-linux-gnu/libz. so.1
0x0000003f854df610 0x0000003f854f41a0 Yes (*) /lib/riscv64-linux-gnu/libex pat.so.1
0x0000003f853852b0 0x0000003f85465388 Yes /lib/riscv64-linux-gnu/libc. so.6
0x0000003f855bdce0 0x0000003f855d3d4e Yes /lib/ld-linux-riscv64-lp64d. so.1
0x0000003f84227b00 0x0000003f844b84e0 Yes (*) /home/lzdz/myenv/lib/python3 .12/site-packages/numpy/_core/_multiarray_umath.cpython-312-riscv64-linux-gnu.so
0x0000003f838974f0 0x0000003f83f15af2 Yes (*) /home/lzdz/myenv/lib/python3 .12/site-packages/numpy/_core/../../numpy.libs/libopenblas_x60p-r0-8c1e1649.3.32 .so
0x0000003f834a12a0 0x0000003f83590572 Yes (*) /lib/riscv64-linux-gnu/libst dc++.so.6
0x0000003f852c35e0 0x0000003f852d68a0 Yes (*) /lib/riscv64-linux-gnu/libgc c_s.so.1
0x0000003f840b9a50 0x0000003f841b2dfa Yes (*) /home/lzdz/myenv/lib/python3 .12/site-packages/numpy/_core/../../numpy.libs/libgfortran-a4c28458.so.5.0.0
0x0000003f855ab670 0x0000003f855ab768 Yes /usr/lib/python3.12/lib-dynl oad/_contextvars.cpython-312-riscv64-linux-gnu.so
0x0000003f845e68a0 0x0000003f845f34fe Yes /usr/lib/python3.12/lib-dynl oad/_ctypes.cpython-312-riscv64-linux-gnu.so
0x0000003f855a38d0 0x0000003f855a724c Yes (*) /lib/riscv64-linux-gnu/libff i.so.8
0x0000003f84073940 0x0000003f84092b1e Yes (*) /home/lzdz/myenv/lib/python3 .12/site-packages/numpy/linalg/_umath_linalg.cpython-312-riscv64-linux-gnu.so
0x0000003f6e736ea0 0x0000003f6f455ce4 Yes (*) /usr/lib/python3.12/dist-pac kages/onnxruntime/capi/libonnxruntime.so.1.24.0+spacemit.a3
0x0000003f8559f4a0 0x0000003f8559f57c Yes (*) /usr/lib/python3.12/dist-pac kages/onnxruntime/capi/libonnxruntime_providers_shared.so
0x0000003f6f8c6920 0x0000003f6f9a3bd6 Yes (*) /usr/lib/python3.12/dist-pac kages/onnxruntime/capi/onnxruntime_pybind11_state.so
0x0000003f6dd164e0 0x0000003f6e09ec14 Yes (*) /home/lzdz/spacemit-demo-mai n/spacemit_ort_2.0.5/spacemit_ort/libspacemit_ep.so.2.0.5
0x0000003f85285d00 0x0000003f85287e14 Yes (*) /lib/riscv64-linux-gnu/libat omic.so.1
0x0000003f845d79c0 0x0000003f845da546 Yes (*) /lib/libspine_tcm.so
0x0000003f852f57e0 0x0000003f852f6b3e Yes /usr/lib/python3.12/lib-dynl oad/_bz2.cpython-312-riscv64-linux-gnu.so
0x0000003f852e4310 0x0000003f852efb78 Yes (*) /lib/riscv64-linux-gnu/libbz 2.so.1.0
0x0000003f836f84d0 0x0000003f836fb16a Yes /usr/lib/python3.12/lib-dynl oad/_lzma.cpython-312-riscv64-linux-gnu.so
0x0000003f836b3120 0x0000003f836ca060 Yes (*) /lib/riscv64-linux-gnu/liblz ma.so.5
0x0000003f8367d1f0 0x0000003f836a47ce Yes (*) /home/lzdz/myenv/lib/python3 .12/site-packages/numpy/random/_bounded_integers.cpython-312-riscv64-linux-gnu.s o
0x0000003f83650810 0x0000003f83668b4c Yes (*) /home/lzdz/myenv/lib/python3 .12/site-packages/numpy/random/bit_generator.cpython-312-riscv64-linux-gnu.so
0x0000003f85295340 0x0000003f852b706e Yes (*) /home/lzdz/myenv/lib/python3 .12/site-packages/numpy/random/_common.cpython-312-riscv64-linux-gnu.so
0x0000003f836ebf20 0x0000003f836ef82a Yes /usr/lib/python3.12/lib-dynl oad/_hashlib.cpython-312-riscv64-linux-gnu.so
0x0000003f67cb2d00 0x0000003f67e4f632 Yes (*) /lib/riscv64-linux-gnu/libcr ypto.so.3
0x0000003f6e263c90 0x0000003f6e2b3506 Yes (*) /home/lzdz/myenv/lib/python3 .12/site-packages/numpy/random/_generator.cpython-312-riscv64-linux-gnu.so
0x0000003f6f893630 0x0000003f6f8a1336 Yes (*) /home/lzdz/myenv/lib/python3 .12/site-packages/numpy/random/_pcg64.cpython-312-riscv64-linux-gnu.so
0x0000003f6f8780d0 0x0000003f6f88507a Yes (*) /home/lzdz/myenv/lib/python3 .12/site-packages/numpy/random/_mt19937.cpython-312-riscv64-linux-gnu.so
0x0000003f6f85f280 0x0000003f6f86bbec Yes (*) /home/lzdz/myenv/lib/python3 .12/site-packages/numpy/random/_philox.cpython-312-riscv64-linux-gnu.so
0x0000003f6e24bbf0 0x0000003f6e252f3c Yes (*) /home/lzdz/myenv/lib/python3 .12/site-packages/numpy/random/_sfc64.cpython-312-riscv64-linux-gnu.so
0x0000003f6c27e210 0x0000003f6c2b6ea2 Yes (*) /home/lzdz/myenv/lib/python3 .12/site-packages/numpy/random/mtrand.cpython-312-riscv64-linux-gnu.so
(*): Shared library is missing debugging information.
