A fresh-install, end-to-end walkthrough on an Orange Pi RV2: reproduce a silent NaN failure in the stock EESSI HPL, trace it to one RISC-V vector kernel, and fix it — correct results — with a single eb --from-pr.
TL;DR¶
- The Orange Pi RV2 (SpaceMiT K1, eight X60 cores) is a vector RISC-V board: RVV 1.0, VLEN=256. Unlike the scalar SiFive U74, its OpenBLAS already has a mature RVV GEMM kernel (
RISCV64_ZVL256B), and the stock EESSI OpenBLAS 0.3.30 is aDYNAMIC_ARCHbuild that does dispatch it on this chip. - So RVV is engaged out of the box — but the result is wrong: stock EESSI HPL fails with residual
nanon the X60. The run even reports a healthy-looking ~8.5 GFLOP/s; only the residual check reveals the answer is garbage. - The cause is a one-kernel bug in OpenBLAS 0.3.30’s RVV
gemv_n(it zeroes an uninitialized vector register). It was fixed upstream in v0.3.31 (OpenMathLib/OpenBLAS#5408). Backporting that single kernel restores correctness: HPL passes (residual ~4e-03). - The fix is packaged for EESSI as an EasyBuild easyconfig + patch (easybuilders/easybuild-easyconfigs#26444). This post reproduces the whole thing from a clean CVMFS stack: see the NaN, build the fix straight from the PR, swap it in with FlexiBLAS, and watch HPL pass — without recompiling HPL.
Everything below was run on a real Orange Pi RV2, entirely from the EESSI CVMFS stack.
https://www.eessi.io/docs/blog/2026/07/12/risc-v-x60-openblas-hpl/
