K3 CoM260 Kit MIPI CSI 2+2+4 Mode Hardware Configuration
Hi, I saw the following description in the K3 CoM260 Kit specifications:
MIPI interfaces: 1 × 2-lane MIPI DSI FPC interface; 2 × 4-lane MIPI CSI FPC interfaces, supporting “4+4”, “4+2+2”, or “2+2+2+2” link configurations
But later it says:
The K3-CoM260 is not limited to specific camera module models. Its high-speed connector provides two sets of 4-lane MIPI CSI signals, and different link configurations can be selected flexibly through resistor configurations on the module.
In the default configuration,
CAM0 supports 2 lanes
CAM1 supports 2+2 lanes or 4 lanes
I’d like to configure CAM0 for 2+2 lanes and CAM1 for 4 lanes. What hardware changes do I need to make?
而CAM0只有一组时钟差分对,那么2+2模式下,是两个sensor共用时钟吗
Pin信号名称
|1|VDD_3V3_SYS
|2|I2C4_SDA
|3|I2C4_SCL
|4|GND
|5|CLK_CAMCK
|6|CAM_PWDN
|7|GND
|8|MIPI_CSI0_DP1
|9|MIPI_CSI0_DN1
|10|GND
|11|MIPI_CSI0_DP0
|12|MIPI_CSI0_DN0
|13|GND
|14|MIPI_CSI1_CLKP
|15|MIPI_CSI1_CLKN
|16|GND
|17|MIPI_CSI1_DP1
|18|MIPI_CSI1_DN1
|19|GND
|20|MIPI_CSI1_DP0
|21|MIPI_CSI1_DN0
|22|GND
你好:
  1. 只有CAM1的CSI2支持2+2,CAM0的CSI0不支持。
  2. CAM1只有CSI2的4Lane和CSI2的CLK,2+2需要额外需要飞线,因为没有CSI3的MIPI CLK。
你好,那么要满足 2+2+4lane 模式下工作的话,我看了K3 CoM260 Kit核心板接口定义:
GND 1 2 GND
MIPI_CSI0_DN0 3 4 MIPI_CSI1_DN0
MIPI_CSI0_DP0 5 6 MIPI_CSI1_DP0
GND 7 8 GND
MIPI_CSI0_CLKN 9 10 MIPI_CSI1_CLKN
MIPI_CSI0_CLKP 11 12 MIPI_CSI1_CLKP
GND 13 14 GND
MIPI_CSI0_DN1 15 16 MIPI_CSI1_DN1
MIPI_CSI0_DP1 17 18 MIPI_CSI1_DP1
GND 19 20 GND
MIPI_CSI2_DN2 21 22 MIPI_CSI2_DN0
MIPI_CSI2_DP2 23 24 MIPI_CSI2_DP0
GND 25 26 GND
MIPI_CSI3_CLKN 27 28 MIPI_CSI2_CLKN
MIPI_CSI3_CLKP 29 30 MIPI_CSI2_CLKP
GND 31 32 GND
MIPI_CSI2_DN3 33 34 MIPI_CSI2_DN1
MIPI_CSI2_DP3 35 36 MIPI_CSI2_DP1
GND 37 38 GND
CSI0、CSI1分别是2lane 数据+时钟差分对,CSI2 是4lane 数据+时钟差分对,我画底板将CSI0、CSI1、CSI2 信号引出,这样是否可行呢?因为我看到资料中原理图中的定义与手册中的定义不太一致,所以我需要确定按照手册中的定义,是否可行。
你好,你分析的信号脚没有问题,再补充pwdn和mclk信号就可以
