I’m currently trying to port our RTOS to the K1 and need to adapt the interrupt controller driver. What interrupt controller does the K1 use? Is it a PLIC with a base address of 0xe0000000?
Which parts of the kernel code can I refer to when adapting the driver?
求助求助![]()
K1 中断控制器:PLIC ,基地址
0xe0000000,compatible ="riscv,plic0" -
8 核全连接(cpu0~cpu7 的 M/S 两个 context)
参考驱动:drivers/irqchip/irq-sifive-plic.c
这个驱动同时支持 sifive,plic-1.0.0 和 riscv,plic0 两个 compatible,K1 直接复用这个驱动
