The board uses a SpacemiT Keystone K1 and currently fails to boot normally. The symptoms are as follows:
- After power is applied, the LED stays red and never turns green as it does during a normal boot.
- The areas around the K1 and PMIC are completely cold, suggesting that the main power rail may not be starting up.
- The onboard USB-to-serial interface is recognized by the computer:
- Device: /dev/ttyACM2
- VID:PID: 1a86:55d3
- Product name: USB Single Serial
- Serial number: 56D1000897
- Driver: cdc_acm
- The serial port opens normally and is monitored at 115200 8N1, but there is no output after pressing RST or cycling the power.
- The following FDL procedures have been attempted:
- Disconnect power completely, hold FDL, and reconnect power;
- Hold FDL, then briefly press RST;
- Hold FDL for several seconds, then release it.
Currently, only the onboard WCH USB-to-serial interface enumerates. The K1 itself appears not to have completed its power-up sequence, and there is no
BootROM, FSBL, or U-Boot output on the serial port.
Questions:
- Does a solid red LED indicate a problem with PMIC power-up or the main power rail?
- What is the correct timing sequence for entering FDL mode on the Keystone K1, and which USB interface is used for downloading?
- Are there recommended power test points to measure, and what are their normal voltage values?
Thanks for your help.
