【Urgent help】K3 OpenOCD connection keeps failing
  1. 参考文档链接
    SpacemiT
  2. 按照文档去掉J-Link跳线帽。
  3. Linux系统。拷贝60-openocd.rules到/etc/udev/rules.d并刷新udev规则。
  4. 运行脚本k3.sh,连接失败;运行其他k3-xxx.sh脚本,现象一样。
    报错log如下(两次区别是一次连了J-Link的Vref脚,一次没连,结果都是失败):
> test@test-ZhaoYang-X5-14-IRL:~/K3/spacemit-openocd-linux-V1.1.2/bin$ ./k3.sh
> Open On-Chip Debugger 0.12.0+dev-g57f52fa (2026-06-10-07:54)
> Licensed under GNU GPL v2
> For bug reports, read
> http://openocd.org/doc/doxygen/bugs.html
> 8000
> 0
> acpu
> 0 1 2 3
> 0 1 2 3
> 0 1 2 3
> 0 1 2 3
> 0 1 2 3
> 0
> 0
> 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
> 0 1 2 3
> sbawrite32
> Info : [k3.x100.0] Hardware thread awareness created
> Info : [k3.x100.4] Hardware thread awareness created
> Info : [k3.a100.8] Hardware thread awareness created
> Info : [k3.a100.12] Hardware thread awareness created
> Info : J-Link Pro V4 compiled Sep 22 2029 15:00:37
> Info : Hardware version: 11.00
> Info : VTarget = 3.260 V
> Info : clock speed 2000 kHz
> Error: JTAG scan chain interrogation failed: all ones
> Error: Check JTAG interface, timings, target power, etc.
> Error: Trying to use configured scan chain anyway...
> Error: post.unknown: IR capture error; saw 0x1ff not 0x1
> Warn : Bypassing JTAG setup events due to errors
> Info : [k3.x100.0] starting gdb server on 1024
> Info : Listening on port 1024 for gdb connections
> Error: [k3.x100.0] set_group is not implemented for this target.
> scripts/spacemit-k3.cfg:145: Error:
> Traceback (most recent call last):
> File "scripts/spacemit-k3.cfg", line 145, in script
> {k3.x100.0 riscv set_group} halt_group 0 trigger 0
> Error: [k3.x100.0] Unsupported DTM version: -1
> Error: [k3.x100.0] Could not identify target type.
> Error: [k3.x100.1] Unsupported DTM version: -1
> Error: [k3.x100.1] Could not identify target type.
> Error: [k3.x100.2] Unsupported DTM version: -1
> Error: [k3.x100.2] Could not identify target type.
> Error: [k3.x100.3] Unsupported DTM version: -1
> Error: [k3.x100.3] Could not identify target type.
> Error: [k3.x100.4] Unsupported DTM version: -1
> Error: [k3.x100.4] Could not identify target type.
> Error: [k3.x100.5] Unsupported DTM version: -1
> Error: [k3.x100.5] Could not identify target type.
> Error: [k3.x100.6] Unsupported DTM version: -1
> Error: [k3.x100.6] Could not identify target type.
> Error: [k3.x100.7] Unsupported DTM version: -1
> Error: [k3.x100.7] Could not identify target type.
> Error: [k3.a100.8] Unsupported DTM version: -1
> Error: [k3.a100.8] Could not identify target type.
> Error: [k3.a100.9] Unsupported DTM version: -1
> Error: [k3.a100.9] Could not identify target type.
> Error: [k3.a100.10] Unsupported DTM version: -1
> Error: [k3.a100.10] Could not identify target type.
> Error: [k3.a100.11] Unsupported DTM version: -1
> Error: [k3.a100.11] Could not identify target type.
> Error: [k3.a100.12] Unsupported DTM version: -1
> Error: [k3.a100.12] Could not identify target type.
> Error: [k3.a100.13] Unsupported DTM version: -1
> Error: [k3.a100.13] Could not identify target type.
> Error: [k3.a100.14] Unsupported DTM version: -1
> Error: [k3.a100.14] Could not identify target type.
> Error: [k3.a100.15] Unsupported DTM version: -1
> Error: [k3.a100.15] Could not identify target type.
> 8000
> 0
> acpu
> 0 1 2 3
> 0 1 2 3
> 0 1 2 3
> 0 1 2 3
> 0 1 2 3
> 0
> 0
> 0 1 2 3
> sbawrite32
> Info : VTarget = 0.000 V
  1. 我把测试环境拍了几张照片,请各位大佬帮忙检查一下。
整体环境
用飞线连接板端Pri JTAG
J-Link的GND和板端UART的GND连接
J-Link端连线(角度1)
J-Link端连线(角度2)
看你的接线好像没问题,板子应该上电了吧
我这边是可以的:
liangzhen@liangzhen-ubuntu:~/workspace/spacemit-openocd-linux-V1.1.2/bin$ ./k3.sh
8000
0
acpu
0 1 2 3
0 1 2 3
0 1 2 3
0 1 2 3
0 1 2 3
0
0
0 1 2 3
sbawrite32
Info : J-Link V9 compiled May  7 2021 16:26:12
Info : Hardware version: 9.40
Info : VTarget = 3.266 V
Info : JTAG tap: post.unknown tap/device found: 0x08502c0d (mfg: 0x606 (Shenzhen Chixingzhe Technology Co Ltd), part: 0x8502, ver: 0x0)
Info : JTAG tap: pre.unknown enabled
Info : JTAG tap: k3.cpu enabled
Info : [k3.x100.0] datacount=2 progbufsize=2
Info : [k3.x100.0] Vector support with vlenb=32
Info : [k3.x100.0] S?aia detected with IMSIC
Info : [k3.x100.0] Core 0 made part of halt group 1.
Info : [k3.x100.0] Examined RISC-V core
Info : [k3.x100.0]  XLEN=64, misa=0x8000000000b411af
Info : [k3.x100.0] Examination succeed
Info : [k3.x100.1] datacount=2 progbufsize=2
Info : [k3.x100.1] Vector support with vlenb=32
Info : [k3.x100.1] S?aia detected with IMSIC
Info : [k3.x100.1] Core 1 made part of halt group 1.
Info : [k3.x100.1] Examined RISC-V core
Info : [k3.x100.1]  XLEN=64, misa=0x8000000000b411af
Info : [k3.x100.1] Examination succeed
Info : [k3.x100.2] datacount=2 progbufsize=2
Info : [k3.x100.2] Vector support with vlenb=32
Info : [k3.x100.2] S?aia detected with IMSIC
Info : [k3.x100.2] Core 2 made part of halt group 1.
Info : [k3.x100.2] Examined RISC-V core
Info : [k3.x100.2]  XLEN=64, misa=0x8000000000b411af
Info : [k3.x100.2] Examination succeed
Info : [k3.x100.3] datacount=2 progbufsize=2
Info : [k3.x100.3] Vector support with vlenb=32
Info : [k3.x100.3] S?aia detected with IMSIC
Info : [k3.x100.3] Core 3 made part of halt group 1.
Info : [k3.x100.3] Examined RISC-V core
Info : [k3.x100.3]  XLEN=64, misa=0x8000000000b411af
Info : [k3.x100.3] Examination succeed
Info : [k3.x100.4] datacount=2 progbufsize=2
Info : [k3.x100.4] Vector support with vlenb=32
Info : [k3.x100.4] S?aia detected with IMSIC
Info : [k3.x100.4] Core 0 made part of halt group 1.
Info : [k3.x100.4] Examined RISC-V core
Info : [k3.x100.4]  XLEN=64, misa=0x8000000000b411af
Info : [k3.x100.4] Examination succeed
Info : [k3.x100.5] datacount=2 progbufsize=2
Info : [k3.x100.5] Vector support with vlenb=32
Info : [k3.x100.5] S?aia detected with IMSIC
Info : [k3.x100.5] Core 1 made part of halt group 1.
Info : [k3.x100.5] Examined RISC-V core
Info : [k3.x100.5]  XLEN=64, misa=0x8000000000b411af
Info : [k3.x100.5] Examination succeed
Info : [k3.x100.6] datacount=2 progbufsize=2
Info : [k3.x100.6] Vector support with vlenb=32
Info : [k3.x100.6] S?aia detected with IMSIC
Info : [k3.x100.6] Core 2 made part of halt group 1.
Info : [k3.x100.6] Examined RISC-V core
Info : [k3.x100.6]  XLEN=64, misa=0x8000000000b411af
Info : [k3.x100.6] Examination succeed
Info : [k3.x100.7] datacount=2 progbufsize=2
Info : [k3.x100.7] Vector support with vlenb=32
Info : [k3.x100.7] S?aia detected with IMSIC
Info : [k3.x100.7] Core 3 made part of halt group 1.
Info : [k3.x100.7] Examined RISC-V core
Info : [k3.x100.7]  XLEN=64, misa=0x8000000000b411af
Info : [k3.x100.7] Examination succeed
Info : [k3.a100.8] datacount=2 progbufsize=2
Info : [k3.a100.8] Vector support with vlenb=128
Info : [k3.a100.8] S?aia detected with IMSIC
Info : [k3.a100.8] Core 0 made part of halt group 1.
Info : [k3.a100.8] Examined RISC-V core
Info : [k3.a100.8]  XLEN=64, misa=0x8000000000b4112f
Info : [k3.a100.8] Examination succeed
Info : [k3.a100.9] datacount=2 progbufsize=2
Info : [k3.a100.9] Vector support with vlenb=128
Info : [k3.a100.9] S?aia detected with IMSIC
Info : [k3.a100.9] Core 1 made part of halt group 1.
Info : [k3.a100.9] Examined RISC-V core
Info : [k3.a100.9]  XLEN=64, misa=0x8000000000b4112f
Info : [k3.a100.9] Examination succeed
Info : [k3.a100.10] datacount=2 progbufsize=2
Info : [k3.a100.10] Vector support with vlenb=128
Info : [k3.a100.10] S?aia detected with IMSIC
Info : [k3.a100.10] Core 2 made part of halt group 1.
Info : [k3.a100.10] Examined RISC-V core
Info : [k3.a100.10]  XLEN=64, misa=0x8000000000b4112f
Info : [k3.a100.10] Examination succeed
Info : [k3.a100.11] datacount=2 progbufsize=2
Info : [k3.a100.11] Vector support with vlenb=128
Info : [k3.a100.11] S?aia detected with IMSIC
Info : [k3.a100.11] Core 3 made part of halt group 1.
Info : [k3.a100.11] Examined RISC-V core
Info : [k3.a100.11]  XLEN=64, misa=0x8000000000b4112f
Info : [k3.a100.11] Examination succeed
Info : [k3.a100.12] datacount=2 progbufsize=2
Info : [k3.a100.12] Vector support with vlenb=128
Info : [k3.a100.12] S?aia detected with IMSIC
Info : [k3.a100.12] Core 0 made part of halt group 1.
Info : [k3.a100.12] Examined RISC-V core
Info : [k3.a100.12]  XLEN=64, misa=0x8000000000b4112f
Info : [k3.a100.12] Examination succeed
Info : [k3.a100.13] datacount=2 progbufsize=2
Info : [k3.a100.13] Vector support with vlenb=128
Info : [k3.a100.13] S?aia detected with IMSIC
Info : [k3.a100.13] Core 1 made part of halt group 1.
Info : [k3.a100.13] Examined RISC-V core
Info : [k3.a100.13]  XLEN=64, misa=0x8000000000b4112f
Info : [k3.a100.13] Examination succeed
Info : [k3.a100.14] datacount=2 progbufsize=2
Info : [k3.a100.14] Vector support with vlenb=128
Info : [k3.a100.14] S?aia detected with IMSIC
Info : [k3.a100.14] Core 2 made part of halt group 1.
Info : [k3.a100.14] Examined RISC-V core
Info : [k3.a100.14]  XLEN=64, misa=0x8000000000b4112f
Info : [k3.a100.14] Examination succeed
Info : [k3.a100.15] datacount=2 progbufsize=2
Info : [k3.a100.15] Vector support with vlenb=128
Info : [k3.a100.15] S?aia detected with IMSIC
Info : [k3.a100.15] Core 3 made part of halt group 1.
Info : [k3.a100.15] Examined RISC-V core
Info : [k3.a100.15]  XLEN=64, misa=0x8000000000b4112f
adapter speed: 8000 kHz
    TargetName         Type       Endian TapName            State
 0  k3.x100.0          riscv      little k3.cpu             running
 1  k3.x100.1          riscv      little k3.cpu             running
 2  k3.x100.2          riscv      little k3.cpu             running
 3  k3.x100.3          riscv      little k3.cpu             running
 4  k3.x100.4          riscv      little k3.cpu             running
 5  k3.x100.5          riscv      little k3.cpu             running
 6  k3.x100.6          riscv      little k3.cpu             running
 7  k3.x100.7          riscv      little k3.cpu             running
 8  k3.a100.8          riscv      little k3.cpu             running
 9  k3.a100.9          riscv      little k3.cpu             running
10  k3.a100.10         riscv      little k3.cpu             running
11  k3.a100.11         riscv      little k3.cpu             running
12  k3.a100.12         riscv      little k3.cpu             running
13  k3.a100.13         riscv      little k3.cpu             running
14  k3.a100.14         riscv      little k3.cpu             running
15* k3.a100.15         riscv      little k3.cpu             running
Info : [k3.a100.15] Examination succeed
Info : [k3.x100.0] External trigger 0 made part of halt group 0.
Info : [k3.x100.4] External trigger 0 made part of halt group 0.
Info : [k3.a100.8] External trigger 0 made part of halt group 0.
Info : [k3.a100.12] External trigger 0 made part of halt group 0.
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
我看你一共连了5根信号线和1根GND共6根线,Vref不用连接吗,但我看你log打印VTarget = 3.266 V。我不连的话VTarget = 0 V。
另外J-Link里面跳线帽拔掉了吧?
跳线帽没拔,使用J-Link 内部供电,应该和Vref通过板子供电一样。
谢谢。
我检查了硬件应该没什么问题。
JTAG的GPIO复用功能需要单独配置吗,我现在是uboot起来之后进入系统了。
这个类型的板子不用的
@luberapple 我与你一样,你解决了吗?
