用 titantools 刷机后无法启动
镜像: https://archive.spacemit.com/image/k1/version/bianbu/v2.3.3/Bianbu-LXQt-K1-V2.3.3-UEFI-20260407142626.zip
使用 titantools 显示刷机成功,重新上电以后无法启动
串口日志:
sys: 0x200
try sd...
bm:3
ERROR:   CMD8
ERROR:   sd f! l:76
bm:4
nor m:0xef d:0x6017
j...
U-Boot SPL 2022.10spacemit-gdb67f9dc4-dirty (Sep 25 2025 - 07:00:37 +0000)
[   0.226] DDR type LPDDR4X
[   0.226] set ddr tx odt to 80ohm!
[   0.247] lpddr4_silicon_init consume 21ms
[   0.248] Change DDR data rate to 2400MT/s
[   0.284] ## Checking hash(es) for config conf_1 ... OK
[   0.685] ## Checking hash(es) for Image uefi ... OK
[   0.701] ## Checking hash(es) for Image fdt_1 ... OK
[   0.722] ## Checking hash(es) for config config_1 ... OK
[   0.724] ## Checking hash(es) for Image opensbi ... crc32+ OK
SecStartup() BootHartId: 0x0, DeviceTreeAddress=0x4BF000
MemoryPeimInitializationCommon: System RAM @ 0x0 - 0x7FFFFFFF
MemoryPeimInitializationCommon: System RAM @ 0x100000000 - 0x47FFFFFFF
AddReservedMemoryMap: Adding Reserved Memory Addr = 0x0, Size = 0x80000
AddReservedMemoryMap: Adding Reserved Memory Addr = 0x30000000, Size = 0x200000
AddReservedMemoryMap: Adding Reserved Memory Addr = 0x30200000, Size = 0x3000
AddReservedMemoryMap: Adding Reserved Memory Addr = 0x30203000, Size = 0x3000
AddReservedMemoryMap: Adding Reserved Memory Addr = 0x30206000, Size = 0xF6000
AddReservedMemoryMap: Adding Reserved Memory Addr = 0x302FC000, Size = 0x4000
AddReservedMemoryMap: Adding Reserved Memory Addr = 0x30300000, Size = 0x200000
AddReservedMemoryMap: Adding Reserved Memory Addr = 0x2FF40000, Size = 0xC0000
PlatformPeimInitializationCommon: Build FDT HOB - FDT at address: 0x4BF000
Loading DxeCore at 0x00234A4000 EntryPoint=0x00234A50B6
DxeMain: MemoryBaseAddress=0x30500000 MemoryLength=0x4FB00000
HOBLIST address in DXE = 0x7FE3B018
Memory Allocation 0x00000000 0x0 - 0x7FFFF
Memory Allocation 0x00000000 0x30000000 - 0x301FFFFF
Memory Allocation 0x00000000 0x30200000 - 0x30202FFF
Memory Allocation 0x00000000 0x30203000 - 0x30205FFF
Memory Allocation 0x00000000 0x30206000 - 0x302FBFFF
Memory Allocation 0x00000000 0x302FC000 - 0x302FFFFF
Memory Allocation 0x00000000 0x30300000 - 0x304FFFFF
Memory Allocation 0x00000000 0x2FF40000 - 0x2FFFFFFF
Memory Allocation 0x00000004 0x23FD9000 - 0x23FEFFFF
Memory Allocation 0x00000004 0x23FF0000 - 0x23FFFFFF
Memory Allocation 0x00000004 0x23FC9000 - 0x23FD8FFF
Memory Allocation 0x00000004 0x23A67000 - 0x23FC8FFF
Memory Allocation 0x00000004 0x23506000 - 0x23A66FFF
Memory Allocation 0x00000003 0x234A4000 - 0x23505FFF
FV Hob            0x200000 - 0x3FEFFF
FV Hob            0x23506000 - 0x23A65FFF
FV2 Hob           0x23506000 - 0x23A65FFF
                  00000000-0000-0000-0000-000000000000 - 91DA8A5D-2469-49C0-8E37-CA55B92F03E6
InstallProtocolInterface: D8117CFE-94A6-11D4-9A3A-0090273FC14D 234E9390
InstallProtocolInterface: 8F644FA9-E850-4DB1-9CE2-0B44698E8DA4 7FE37330
InstallProtocolInterface: 09576E91-6D3F-11D2-8E39-00A0C969723B 7FE37698
InstallProtocolInterface: 8F644FA9-E850-4DB1-9CE2-0B44698E8DA4 7FE33030
InstallProtocolInterface: 09576E91-6D3F-11D2-8E39-00A0C969723B 7FE33F98
InstallProtocolInterface: 220E73B6-6BDB-4413-8405-B974B108619A 7FE33EB0
InstallProtocolInterface: 220E73B6-6BDB-4413-8405-B974B108619A 7FE32F30
InstallProtocolInterface: FC1BCDB0-7D31-49AA-936A-A4600D9DD083 234E93B0
Loading driver 9B680FCE-AD6B-4F3A-B60B-F59899003443
InstallProtocolInterface: 5B1B31A1-9562-11D2-8E3F-00A0C969723B 7F9A62C0
Loading driver at 0x0007F94A000 EntryPoint=0x0007F94B04A DevicePathDxe.efi
InstallProtocolInterface: BC62157E-3E33-4FEC-9920-2D3B36D750DF 7F949018
ProtectUefiImageCommon - 0x7F9A62C0
  - 0x000000007F94A000 - 0x0000000000016000
InstallProtocolInterface: 0379BE4E-D706-437D-B037-EDB82FB772A4 7F95A408
InstallProtocolInterface: 8B843E20-8132-4852-90CC-551A4E4A7F1C 7F95A448
InstallProtocolInterface: 05C99A21-C70F-4AD2-8A5F-35DF3343F51E 7F95A458
Loading driver 80CF7257-87AB-47F9-A3FE-D50B76D89541
InstallProtocolInterface: 5B1B31A1-9562-11D2-8E3F-00A0C969723B 7F9497C0
Loading driver at 0x0007F93D000 EntryPoint=0x0007F93E04A PcdDxe.efi
InstallProtocolInterface: BC62157E-3E33-4FEC-9920-2D3B36D750DF 7F949698
ProtectUefiImageCommon - 0x7F9497C0
  - 0x000000007F93D000 - 0x000000000000C000
InstallProtocolInterface: 11B34006-D85B-4D0A-A290-D5A571310EF7 7F947018
InstallProtocolInterface: 13A3F0F6-264A-3EF0-F2E0-DEC512342F34 7F947110
InstallProtocolInterface: 5BE40F57-FA68-4610-BBBF-E9C5FCDAD365 7F9471A0
InstallProtocolInterface: FD0F4478-0EFD-461D-BA2D-E58C45FD5F5E 7F9471B8
Loading driver BDEA19E2-778F-473C-BF82-5E38D6A27765
InstallProtocolInterface: 5B1B31A1-9562-11D2-8E3F-00A0C969723B 7F9762C0
Loading driver at 0x0007F931000 EntryPoint=0x0007F932100 CpuDxeRiscV64.efi
InstallProtocolInterface: BC62157E-3E33-4FEC-9920-2D3B36D750DF 7F976698
ProtectUefiImageCommon - 0x7F9762C0
  - 0x000000007F931000 - 0x000000000000C000
 InitializeCpu: Firmware Context is at 0x23FFFFA0.
 InitializeCpu: mBootHartId = 0x0.
RiscVConfigureMmu: SATP mode 8 successfully configured
InstallProtocolInterface: CCD15FEC-6F73-4EEC-8395-3E69E4B940BF 7F93B008
InstallProtocolInterface: 26BACCB1-6F42-11D4-BCE7-0080C73C8881 7F93B018
MemoryProtectionCpuArchProtocolNotify:
ProtectUefiImageCommon - 0x234E93E0
  - 0x00000000234A4000 - 0x0000000000062000
SetUefiImageMemoryAttributes - 0x00000000234A4000 - 0x0000000000001000 (0x0000000000004000)
SetUefiImageMemoryAttributes - 0x00000000234A5000 - 0x0000000000044000 (0x0000000000020000)
SetUefiImageMemoryAttributes - 0x00000000234E9000 - 0x000000000001D000 (0x0000000000004000)
SetUefiImageMemoryAttributes - 0x000000007F94A000 - 0x0000000000001000 (0x0000000000004000)
SetUefiImageMemoryAttributes - 0x000000007F94B000 - 0x0000000000013000 (0x0000000000020000)
SetUefiImageMemoryAttributes - 0x000000007F95E000 - 0x0000000000002000 (0x0000000000004000)
SetUefiImageMemoryAttributes - 0x000000007F93D000 - 0x0000000000001000 (0x0000000000004000)
SetUefiImageMemoryAttributes - 0x000000007F93E000 - 0x0000000000009000 (0x0000000000020000)
SetUefiImageMemoryAttributes - 0x000000007F947000 - 0x0000000000002000 (0x0000000000004000)
SetUefiImageMemoryAttributes - 0x000000007F931000 - 0x0000000000001000 (0x0000000000004000)
SetUefiImageMemoryAttributes - 0x000000007F932000 - 0x0000000000009000 (0x0000000000020000)
SetUefiImageMemoryAttributes - 0x000000007F93B000 - 0x0000000000002000 (0x0000000000004000)
Loading driver 24150AFA-3ADB-4BEB-B7BA-B73082383D7A
InstallProtocolInterface: 5B1B31A1-9562-11D2-8E3F-00A0C969723B 7F9751C0
Loading driver at 0x0007FEC8000 EntryPoint=0x0007FEC904A SpacemitK1QspiDxe.efi
InstallProtocolInterface: BC62157E-3E33-4FEC-9920-2D3B36D750DF 7F975798
ProtectUefiImageCommon - 0x7F9751C0
  - 0x000000007FEC8000 - 0x000000000000B000
SetUefiImageMemoryAttributes - 0x000000007FEC8000 - 0x0000000000001000 (0x0000000000004000)
SetUefiImageMemoryAttributes - 0x000000007FEC9000 - 0x0000000000008000 (0x0000000000020000)
SetUefiImageMemoryAttributes - 0x000000007FED1000 - 0x0000000000002000 (0x0000000000004000)
Set qspi bus clock: 47250000Hz
XIP read max size: 512
rx fifo size:4096, tx fifo size:256, xip buf size=512
XIP read enabled
InstallProtocolInterface: C37B64E7-7352-4560-ACC2-68CADC13CE67 7FFFE8A8
Loading driver 187EAD2E-DCD8-4D49-85BC-23A83E07AE65
InstallProtocolInterface: 5B1B31A1-9562-11D2-8E3F-00A0C969723B 7F960140
Loading driver at 0x0007FEBC000 EntryPoint=0x0007FEBD04A SpiNorFlashDxe.efi
InstallProtocolInterface: BC62157E-3E33-4FEC-9920-2D3B36D750DF 7F960618
ProtectUefiImageCommon - 0x7F960140
  - 0x000000007FEBC000 - 0x000000000000C000
SetUefiImageMemoryAttributes - 0x000000007FEBC000 - 0x0000000000001000 (0x0000000000004000)
SetUefiImageMemoryAttributes - 0x000000007FEBD000 - 0x0000000000009000 (0x0000000000020000)
SetUefiImageMemoryAttributes - 0x000000007FEC6000 - 0x0000000000002000 (0x0000000000004000)
InstallProtocolInterface: 9B70B19B-8A29-4651-9036-2C6AAEAE9EE7 7FFFE728
Loading driver 4D1791B9-AC6B-49C3-9949-37242537D792
InstallProtocolInterface: 5B1B31A1-9562-11D2-8E3F-00A0C969723B 7F92B0C0
Loading driver at 0x0007FEB0000 EntryPoint=0x0007FEB104A FlashFvbDxe.efi
InstallProtocolInterface: BC62157E-3E33-4FEC-9920-2D3B36D750DF 7F92B918
ProtectUefiImageCommon - 0x7F92B0C0
  - 0x000000007FEB0000 - 0x000000000000C000
SetUefiImageMemoryAttributes - 0x000000007FEB0000 - 0x0000000000001000 (0x0000000000004000)
SetUefiImageMemoryAttributes - 0x000000007FEB1000 - 0x0000000000009000 (0x0000000000020000)
SetUefiImageMemoryAttributes - 0x000000007FEBA000 - 0x0000000000002000 (0x0000000000004000)
Detected w25q64dw SPI NOR flash with page size 256 B, erase size 4 KB, total 8 MB
InstallProtocolInterface: 09576E91-6D3F-11D2-8E39-00A0C969723B 7FFFE600
InstallProtocolInterface: 8F644FA9-E850-4DB1-9CE2-0B44698E8DA4 7FFFE5C0
ValidateFvHeader: No Firmware Volume header present
卡住几秒以后会继续跑:
Loading driver F80697E9-7FD6-4665-8646-88E33EF71DFC
InstallProtocolInterface: 5B1B31A1-9562-11D2-8E3F-00A0C969723B 7F92AC40
Loading driver at 0x0007F913000 EntryPoint=0x0007F91404A SecurityStubDxe.efi
InstallProtocolInterface: BC62157E-3E33-4FEC-9920-2D3B36D750DF 7F92A098
ProtectUefiImageCommon - 0x7F92AC40
  - 0x000000007F913000 - 0x000000000000A000
SetUefiImageMemoryAttributes - 0x000000007F913000 - 0x0000000000001000 (0x0000000000004000)
SetUefiImageMemoryAttributes - 0x000000007F914000 - 0x0000000000007000 (0x0000000000020000)
SetUefiImageMemoryAttributes - 0x000000007F91B000 - 0x0000000000002000 (0x0000000000004000)
InstallProtocolInterface: 94AB2F58-1438-4EF1-9152-18941A3A0E68 7F91B010
InstallProtocolInterface: A46423E3-4617-49F1-B9FF-D1BFA9115839 7F91B008
InstallProtocolInterface: 15853D7C-3DDF-43E0-A1CB-EBF85B8F872C 7F91B018
Loading driver C8339973-A563-4561-B858-D8476F9DEFC4
InstallProtocolInterface: 5B1B31A1-9562-11D2-8E3F-00A0C969723B 7F91F040
Loading driver at 0x0007F90C000 EntryPoint=0x0007F90D04A Metronome.efi
InstallProtocolInterface: BC62157E-3E33-4FEC-9920-2D3B36D750DF 7F91FE18
ProtectUefiImageCommon - 0x7F91F040
  - 0x000000007F90C000 - 0x0000000000007000
SetUefiImageMemoryAttributes - 0x000000007F90C000 - 0x0000000000001000 (0x0000000000004000)
SetUefiImageMemoryAttributes - 0x000000007F90D000 - 0x0000000000004000 (0x0000000000020000)
SetUefiImageMemoryAttributes - 0x000000007F911000 - 0x0000000000002000 (0x0000000000004000)
InstallProtocolInterface: 26BACCB2-6F42-11D4-BCE7-0080C73C8881 7F911008
Loading driver 055DDAC6-9142-4013-BF20-FC2E5BC325C9
InstallProtocolInterface: 5B1B31A1-9562-11D2-8E3F-00A0C969723B 7F91F340
Loading driver at 0x0007F920000 EntryPoint=0x0007F92104A CpuTimerDxeRiscV64.efi
InstallProtocolInterface: BC62157E-3E33-4FEC-9920-2D3B36D750DF 7F91F818
ProtectUefiImageCommon - 0x7F91F340
  - 0x000000007F920000 - 0x0000000000008000
SetUefiImageMemoryAttributes - 0x000000007F920000 - 0x0000000000001000 (0x0000000000004000)
SetUefiImageMemoryAttributes - 0x000000007F921000 - 0x0000000000005000 (0x0000000000020000)
SetUefiImageMemoryAttributes - 0x000000007F926000 - 0x0000000000002000 (0x0000000000004000)
TimerDriverInitialize: Timer interrupt is via Sstc extension
TimerDriverSetTimerPeriod(0x0)
RegisterCpuInterruptHandler: Type:5 Handler: 7F921334
TimerDriverSetTimerPeriod(0x186A0)
InstallProtocolInterface: 26BACCB3-6F42-11D4-BCE7-0080C73C8881 7F926008
TimerDriverRegisterHandler(0x234C1DCA) called
Loading driver B601F8C4-43B7-4784-95B1-F4226CB40CEE
InstallProtocolInterface: 5B1B31A1-9562-11D2-8E3F-00A0C969723B 7F91EBC0
Loading driver at 0x0007FEA6000 EntryPoint=0x0007FEA704A RuntimeDxe.efi
InstallProtocolInterface: BC62157E-3E33-4FEC-9920-2D3B36D750DF 7F91E898
ProtectUefiImageCommon - 0x7F91EBC0
  - 0x000000007FEA6000 - 0x000000000000A000
SetUefiImageMemoryAttributes - 0x000000007FEA6000 - 0x0000000000001000 (0x0000000000004000)
SetUefiImageMemoryAttributes - 0x000000007FEA7000 - 0x0000000000007000 (0x0000000000020000)
SetUefiImageMemoryAttributes - 0x000000007FEAE000 - 0x0000000000002000 (0x0000000000004000)
InstallProtocolInterface: B7DFB4E1-052F-449F-87BE-9818FC91B733 7FEAE008
Loading driver CBD2E4D5-7068-4FF5-B462-9822B4AD8D60
InstallProtocolInterface: 5B1B31A1-9562-11D2-8E3F-00A0C969723B 7F91D040
Loading driver at 0x0007FE8A000 EntryPoint=0x0007FE8B04A VariableRuntimeDxe.efi
InstallProtocolInterface: BC62157E-3E33-4FEC-9920-2D3B36D750DF 7F91DE98
ProtectUefiImageCommon - 0x7F91D040
  - 0x000000007FE8A000 - 0x000000000001C000
SetUefiImageMemoryAttributes - 0x000000007FE8A000 - 0x0000000000001000 (0x0000000000004000)
SetUefiImageMemoryAttributes - 0x000000007FE8B000 - 0x0000000000019000 (0x0000000000020000)
SetUefiImageMemoryAttributes - 0x000000007FEA4000 - 0x0000000000002000 (0x0000000000004000)
VarCheckLibRegisterSetVariableCheckHandler - 0x7FE9CD08 Success
Variable Store header is corrupted
ASSERT_EFI_ERROR (Status = Volume Corrupt)
ASSERT [VariableRuntimeDxe] VariableDxe.c(548): !(((RETURN_STATUS)(Status)) >= 0x8000000000000000ULL)
然后就没有然后了。
刷uboot版本可以启动吗
